Wheel Sizes & Offsets For Skylines
no you just said that they weren't based off manufacturers,
Did I?
....Whilst Australian Standards are developed in conjunction with manufacturers (along with engineers, industry professionals and international associations)...
where does it say that?
Look Fellas, I didn't come on here to argue fact versus fiction with you. I simply tried to provide some facts about what's legal and what's not, and as I have said numerous times, it's up to the individual to use those facts as they see fit. If like yourselves people choose to ignore the facts, then so be it. It's got nothing to do with me and as Braddd has pointed out it's up to the police to enforce them. However we have already proven that bogus advice has already cost one user alr33x a defect, so where's the harm in clearing up the confusion? I'm sure if he knew the legalities before fitting said tyres he might not have done it.
I never said a stretched tyre is unsafe....
I never said don't do it....
I'm still trying to figure out what you are arguing about here...how can people make an educated decision if they don't have both sides of the story?
Facts do not cease to exist because they are ignored.
Edited by thewheeldeal.com.au
i made a statement that the ADR's didnt carry any merit of their own (them doing individual testing themselves), you said that was true, from this we deduce that you think that ADR's are based off them doing their own testing.
bigger turbo, fuel system, computer, fmic, steel induction etc etc etc, i'd be glad if i only copped a defect for tyre size :ninja:
and dont say that it'd get me pulled over and then checked, as we all know coppers love to pull over skylines no matter what the wheel/tyre situation anyway
hey guys just wondering... i have a r34 gtt and want to know what size rims i can get without any modifications. i got a quote from work and they seem to think i can have 18x9 front and 18x10 back. didnt say anythink about offset. offset and tyre sizes would be a big help thanks. also whats the biggest i can go legally??
Edited by pplatr34
also still running stock suspention and i dont mind rolling my rear gaurds alil. after reading alot of these pages i think rear: 18x10 + 18
front: 18x9 + 12 should do the job.
Edited by pplatr34
Pretty agressive. Should look good. You'll have to roll front and rear I believe.
ok so ive been told that theres abit involed in fitting those size on. can any1 reccomened the offset for work xd9z to fit snug in stock gaurds?
Edited by pplatr34
Just copy and fill in the table;
Skyline model = r32 gts-t 4door
Wheel diameter = 18"
Wheel width = 8.5 front / 9.5 rear
Wheel offset = +30 front / +35 rear
Tyre size = 225/40 front / 245/40 rear
Modifications to fit = Need low profile tyres to clear the control arms up front. Rears stick out about 2cm past guards so need stretch fit tyres
Hi guys,
can anyone tell me the offset that would fit flush with the 33 guards
front 18x8.5
rear 18x9.5
been reading this topic but just cant find it, always slightly in or out
Hi guys,
front 18x8.5
rear 18x9.5
that shit is useless without offsets mate...
find out the offsets first
is that all i have to do???????
Sorry I don't know 34s that well. It'll look good. Just might cost a bit to make them fit. I think guards will need bit of a pump.
I know a mate is running 18x10's +22 on his 34 and they fit ok with 235's front and back so going by that you'll be 4mm wider at the back and about 2mm further in at the front if you use a 235 tyre. Or maybe he has 245's.... I can't remember. Anyway his didn't scrub.
I'd go 235's front and 245's at back and make em fit.
need some help here guys.
17 x 8 up front
17x 9 on rear, +44 offset, kinda homo atm as you can see in pic below
ill be pickin up four 25mm bolt on spacers tomoz and see how it looks....
keepin in mind this is track only, thinkin maybe a slight flare on teh guard as well...
wondering if any one knows what size spacers ill need if i want to fill the guards on my r32 gts-t running r34 gt-t stockies, i want the wheels to sit further out to look abit more agressive as i like the look of the r32 wheels.
cheers.
The question of what wheel size fits what Skyline comes up so often I though this might be a good place to post your own wheel dimensions.
Skyline model =
Wheel diameter =
Wheel width =
Wheel offset =
Tyre size =
One of mine as an example;
Skyline model = R32GTST
Wheel diameter = 17"
Wheel width = 8"
Wheel offset = 35
Tyre size = 245/45/17
Modifications to fit = remove the front inner plastic guards, roll rear lip slightly.
:) cheers :)
got pictures of how the wheels sit?
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
