ive gone through almost everyone of these pages, i cant find anyone running, 18x10 with a +18 offset on a R32 GTR, Will they fit on my GTR i want XD9's and they only come in a +18
They fit perfect. I have the same wheels on my GTR with 265/35/18 Federal 595s on. I had some minor scrubbing but nothing a quick guard roll wont fix. :)
offset has nothing to do with brake clearance...
i have had 2 sets of SSR professors, one with low brake clearance and one with hi... the one with hi has a lower offset and clears the brakes by MORE
Hmm
Would 17x8+10 for rears on my 32gtr be ok?
if you wana slice pizza with them yes.
offset does play a part with brake clearance not all wheels have different caliper clearence (too my knowledge) so you would want to be carfeul ie. 18x9 +30 didnt fit on the front of my car it hits the brakes...
the offset is simply the distance from a wheels hub mounting surface to the centerline of the wheel...
a lower or higher offset will move the mounting surface inside the wheel, but its simply the shape of the spokes that can foul on the brakes.
for instance.... lets take say an 18x9+40 vs an 18x9+10 in the same rim... the brake clearance will be exactly the same on both wheels, as all that has happened is the spokes have moved further inwards.
its easier to imagine 2 or 3 peice wheels such as meisters et al where the centre section can be mounted in different spots by the manufacturer, but will always be the same shape
how is the front bar guna make more low?
what you want to do is get rid of fender gap.. front bar will be low regardless once u do that.
cause the 400r bar sits about 20-30mm lower then my sideskirts
so if i get a higher front bar that sits flush with my side skirts i would just lower it 20-30mm and the fender gap will be gone
