Hmmm 41 pages later and I've read 18x9 +30 will fit on the fronts of a R33 GTST25 and some say they won't.
I'm actully more worried it'll hit the upper arm on the inside than the guards as this one is sitting on blisten shocks with king springs. Back should be OK, got 9" on there now with +38
i have the exact same size wheels and yeah, they clear the suspension by a bee's dick. any wider than the 235/40/18 i have on there atm and i reckon it'd foul
Thanks! and btw, nice avatar Hekt1k (van buuren ftw!)
it will fit pending rim design, my 18x9 +30 didnt fit without spacers but they were deep dish rims. GTR wheels will fit no problem and u wont hit any suspension parts at all. ive got 18x9.5 +15 and clears no problems what kinda of rims are u going for?
*cough* rota g-force *cough* got them really cheap XD;; now just need to fix car (not dish rims very...not dish lol)
there is seriously fk all clearance in there Hamish, does your wheel alignment give more room or do you just deal with it?
i'm running a little bit of positive castor and the fronts don't have much camber (basically a standard centreline setup).
no scrubbing at all... but as you said, fuck all clearance...
rota g force will suit your purpose fine plus everyone needs thrash rims i got piaa rozza's which are uglier then ox arse but they serve their purpose.
hamish - fk all clearance is plenty you only have to start worrying when you have below NO clearence cos everyone loves a bit of scrubbing :) oh wait maybe thats just us westies
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
