Hmmm 41 pages later and I've read 18x9 +30 will fit on the fronts of a R33 GTST25 and some say they won't.
I'm actully more worried it'll hit the upper arm on the inside than the guards as this one is sitting on blisten shocks with king springs. Back should be OK, got 9" on there now with +38
i have the exact same size wheels and yeah, they clear the suspension by a bee's dick. any wider than the 235/40/18 i have on there atm and i reckon it'd foul
Thanks! and btw, nice avatar Hekt1k (van buuren ftw!)
it will fit pending rim design, my 18x9 +30 didnt fit without spacers but they were deep dish rims. GTR wheels will fit no problem and u wont hit any suspension parts at all. ive got 18x9.5 +15 and clears no problems what kinda of rims are u going for?
*cough* rota g-force *cough* got them really cheap XD;; now just need to fix car (not dish rims very...not dish lol)
there is seriously fk all clearance in there Hamish, does your wheel alignment give more room or do you just deal with it?
i'm running a little bit of positive castor and the fronts don't have much camber (basically a standard centreline setup).
no scrubbing at all... but as you said, fuck all clearance...
rota g force will suit your purpose fine plus everyone needs thrash rims i got piaa rozza's which are uglier then ox arse but they serve their purpose.
hamish - fk all clearance is plenty you only have to start worrying when you have below NO clearence cos everyone loves a bit of scrubbing :) oh wait maybe thats just us westies
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
