GOT SOME NEW RIMS NOW
18x9.5 +15 te37s
rears will fit sweet (i think perfectly flush)
fronts will stick out about an inch i think so gonna dial in some camber and some stretch and see where we go from there hahaha
Roll the guards perfectly flat with some Cusco camber arms maxed in and they'll fit with ease :)
http://i33.photobucket.com/albums/d85/anml...rx/S6300027.jpg
WHEELS IN THE PICTURE ARE 17=8+5 FRONTS WITH A 215 40 REARS ARE 17=9+10 WITH A 215 40 work vs-mx
OLD WHEELS ON MY 32 KINDA MISS EM ....
ANYWAYS GOT A BIT OF A WHEELS PROBLEM FELLAS RUNNING 16=8-4 rears sit fine atm ...but the fronts arent clearing the brakes .so i put a 5mm slip on on the hub but thene the wheel sits off the hub! (danger!!!) cant put a bolt on on because it sits out a bit as is ...
the wheels have a steel insert was thiknig bout pressing them out and running a SHANKED STYLE WHEEL NUT (HOLDEN ,TOYOTA STYLE)
THAT WAY I CAN RUN THE SPACER TO CLEAR THE BRAKES .AND JUST HAVE A LITTLE MORE PEACE OF MIND AND SUPPORT ON THE WHEELS BTW THE SPACERS ARE 8MM SLIP ON ! ANY SUGGESTIONS WOULD BE APPRECIATED CHEERS FELLAS ..PICS WANTS THERE ALL ON
Edited by talky
pic dont work.
wouldnt bolt on spacers solve your issue as you will have new studs?
asi stted in my previous post ..cannot use bolt on wheel spacers as that will make them 8-20 and will sit mexcian as .so im trying to get around it ...but dont really wanna remove the inserts! but might have to
without looking i'm gonna guess this will be a pic of superlights on a 31
speak to jezzaGTR as he has the same setup (if i'm correct)
hey mate nah its a 32 4 door thought id try something diffrent with the 16s and yer there superlights lol.....so im just trying to get em to work properly arghhh
5mm slip on should make it impossible to put the wheel on..
roll fronts + camber?
or
flare?
easiest option sounds like what u suggested..
mmm its already got a lil flare and i dont wanna the front look stupid compared to the back man mmmm ill see wot happens wene i remove these bloody insetrts cheers man
hey all got me new rimz on work vs-xx dont look to bad
Skyline model = r33
Wheel diameter = 18
Wheel width = fronts 9,rears 10
Wheel offset = fronts +30 with 15mm spacers, rears +25
Tyre size = fronts 225,40 rears 235,40
Modifications to fit = none as yet, fronts scub a real lil bit just going to pull them out a lil bit
yeah they are 9inch rim +30 and 15mm spacers so yeah would be +15
im going to pull the inner guards out and pull the guards out so ill have planty of room
and yeah looks mint niskid CHEA BOI
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
