They will look good and sit fairly flush too. I'd recommend not going overly stretched tyres maybe 225/40 or you could with 215/40. Don't ask tyre shops what they'd recommend they'll tell you to get 255's or something. If your going to go lower then you'll need to roll your guards.
Awesome.. good to know as I was unsure about this, thanks heaps really appreciate it man... the 215/40 would have a slightly lower profile is that right?? (Sidewall 86mm high as opposed to 90mm high on the 225/40's?) but would be more stretched?? (been trying to research as much as possible before asking dumb questions) :)
Now I just need to work out which wheels to go with.. looking for best performance and value for money car is mainly street driven and is currently 200rwkw but I'm hoping to take it up to 230-260rwkw..
So far it appears Toyo's or Federals are the go.. and Michelin Pilot PS2's are the best but they look insanely pricey
thanks again mate
R33 Gts-t series 1
ssr sp1 prffesors
Fronts:
17x10 +11, running spacers to clear brakes :P
require 25mm gaurds with -2.5 camber due to spacers
running 235/45/17 toyo proxxy r1r's
Rear:
18x11 -9
running 245/45/18 bridgestone re050A II
i work at a tyre store and am happy to reccomend outrageous size and am happy to fit them aswell :)
just doesnt come with reciept for fitment :P
i work at a tyre store and am happy to reccomend outrageous size and am happy to fit them aswell :P
haha nice work :) Where you located?
R377 - Nope, its just my shit photography skills!
Woohooo Almost November which means I get my wheels soon..... Hopefully
Oct 20
6:41 Awaiting presentation to customs commissioner SYDNEY AUSTRALIA
Oct 20
7:03 Departure from inward office of exchange SYDNEY AUSTRALIA
Oct 22
9:20 Final delivery 5074 AUSTRALIA
rims have passed customs and looks like they coming from SA?
picking up new advans tonight for my GTT
18x9 fr +22
18x10 r +25
got 225 fronts and 255 rear toyo's on my current wheels, which i'll swap over and trial on the weekend.
guards arent rolled yet, pretty sure i'll need to do that at least.....
as above,but with 235's on the front which are scrubbing the liners...
once new tyres are on guards will be rolled and will add more low (dont need to at the height im at now)
Roll all the guards dead flat for clearance.
Cut the front inner lining so it still stops things getting inside the guard, but so it doesn't interfere at the top where clearance is tight.
Then you'll have no issues at all.
Thanks mate, no issues is obviously what im hoping for!
Yeah after changing pads over the weekend, looks like its only hitting the bump in the liner behind the front wheel on close to full lock atm. Can live with it for now, then when new tyres are on and i go lower I'll reassess.
Very happy with the wheels tho, and once finished will be spot on :P
haha nice work :blink: Where you located?
haha south east, richmond/rowville :(.
wherd u get ur r33 roof spoiler btw man love it lol
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
