er... dood... that's anything but low...
i would say that is just the perspective of the photo as i was trying to get a pic of how the new rubber sat etc. as such it makes the car look quite high as you are looking up into the arches
see my garage pics for normal perspective http://www.skylinesaustralia.com/forums/index.php?app=garage&do=view_image&id=3397
basically you can get your pinky finger in between the top of the tyre n the wheel arch- just
nonethless, horses for courses. I get alot of people commenting how low my car is. To other people its only low if the rims are up under the guards... (i.e. see my other garage pics with the series 1 spoiler n drift suspension)
it's still not that low... it's clearly below stock heaight, but it aint slammed
my point is that you cant run your car at that height and say that people can have low with 275's on a 9.5" +36 rim without flaring your guards or heaps of camber. if anyone tries to slam their car with those specs they will run into trouble.
i run my car lower than yours and had to pull my guards to fit 9.5+25 with a 245/40
exactly. One persons low is another person's stilts.
Worth clarifying in people's minds before they get in and assume a give rim/offset/tyre will fit...
:thumbsup: exactly
Wheel: Lenso/Raiden D1R (Project D)
Skyline model = 1994 R33 GTST
Wheel diameter = 18"
Wheel width = 8.5" Front, 9.0" rear
Wheel offset = +35 Front, +32 Rear
Tyre size = 245/40ZR18 Front 265/35ZR18 Rear
Modifications to fit = Roll Guards
Want to correct the camber a bit so may need to do something with the guards if I do that
Edited by 89CAL
Folks:
All this offset stuff messes with my poor old head...
I have an R33 GTS-T at the stock height.
I'm looking at some old Rays GT2s in 17" x 8.0" all round, with +33 offset.
No troubles with those? Any other thoughts?
Thanks!
Folks:
Thanks!
That will fit without any issues at all
they sit in the guads
Folks:
Thanks!
they'll sit in the guards alot
Folks:
Thanks!
the only useful thought i could provide is look for something better sized. Not saying go grab some 10" wide phat ass wheels but at least an 8/8.5 F and a 9/9.5 R gives you some more tread to work with AND looks 11bty timesbetter.
if you need any help with size/offsets for that let us know. :thumbsup:
as a general rule if you are running wider rubber its always worth rolling your guards at some point you'll likely lower the car too and it will be relevant then so for $50 or so a corner its a good investment to roll ya guards out the way cos if you dont and ya munch your guard cost ya more than $200 to fix it :thumbsup:
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
