haha gotta pay top dollar for top quality !!
have a look at the work emotion series, still good quality & a fair bit cheaper than meisters.
just got myself a set of 18" XD9's which go on tomorrow ! :D
XD9's are sexy!
where's the cheapest place to buy em?
is yours deep dish? what offset?
pictures!!!!!
the thing is, i don't know what offset to use when selecting the wheels. i want something with standard brake caliper clearance, deep dish, 18", no rolling of guards,no tyres that stick out of arches, and no removing of wheel lining.
basically something that fits without modification.
these are the specs i tried plugging in nengun.
offset: 35
width: 8.5jj
18" high buff
then it gives my a box labelled "A". what do i put in that box?
is the price they quote on the site per wheel of for a set of four?
so damn confusing.:/
You enter how many wheels you want to buy, ie 4. NFI what the difference between an A & an O disk is, however.
The price is per wheel.
No it's how many of your nuts you want to trade for a set, no idea why it goes over two though, LOL !
got my wheels done :) powder coated, polished lip, and new tires.
now time for some lowering...or alot.
is it normal for a stock car with GTR wheels (235/45/17 tires) to touch the inner wheel well plastics a little while dropping down gutters (slowly) while steering??
Just copy and fill in the table;
Skyline model = R33 Series 1 GTS
Wheel Brand/Model = Koya Driftek
Wheel diameter = 18"
Wheel width = 8.5"
Wheel offset = +35 (Running F&R)
Tyre size = 235/40/r18 (Front) ... 235/45/r18 (Rear)
Modifications to fit = no mods, fit perfect with 10mm gap to guard at front and 5mm gap to guard at rear. No scraping or rubbing on front full lock or suspension flex at rear. Perfect size if u don't want to mod or roll guards etc.
Some pics:
http://www.skylinesaustralia.com/forums/gallery/image/80399-img-1531jpg/
http://www.skylinesaustralia.com/forums/gallery/image/80405-img-1522jpg/
http://www.skylinesaustralia.com/forums/gallery/image/80404-img-1524jpg/
Wheel width = 8.5"
Some pics:
http://www.skylinesa...99-img-1531jpg/
http://www.skylinesa...05-img-1522jpg/
http://www.skylinesa...04-img-1524jpg/
Looks good mate. I myself also have a non turbo r33, except I'm thinking of running a set of 18" XXR 962's. Reckon it'll fit with 8.5" front and 9.5" back, both with +35 offset? not lowered yet btw
Edited by wikt
8.5's would fit perfect on front.. 9.5's on rears u may hav to roll the guards. I think if u get a smaller offset they may fit, but the whole offset thing still confuses me, I'm probs not the best person to ask lol, check ur nearest decent tyre/wheel shop.. Theyl be able to help.
Not trying to open a can of worms, but I've been reading through this thread and some laws regarding wheel changes, and it occurs to me that I'm probably now running a track width increase that is now illegal (based on an offset calculator, I'd judge 54mm rear, and 46mm front).
Has anyone run into any issues with their increased track with passing through their relevant vehicle regulatory bodies (RTA/Regency/etc), or with insurance claims?
every law needs to be interpreted :pirate: have you tried basing those measurement comparisons on a GTR wheel of your model?
and unless your rolling on monster truck wheels, or Miles out of the guards i don't think you will get hassled anyways. as for insurance, same goes i guess. but in the end it all depends on who your assessor is, and what sort of a mood he is in that day.
*and isnt the track still just measured from the hubs?
Edited by boiracer
R34 GT-T rim is 17x7.5+40
Nismo LMGT4 I have are 18x8.5+30 & 18x9.5+38. They're sitting pretty much on the guards at the front and slightly out at the rear. It's enough to worry about cops when I live in Adelaide (land of the defect). Anyway --
Based on offset calculator:
front is 3mm less clearance inner & outer extend 23mm
rear is 23mm less clearance inner & outer extend 27mm
For R34 GTR (18x9+30), offset calculator:
front/rear is 9mm less clearance inner & outer extend 29mm
So yeah, going from 7.5 to 8.5 front and 9.5 rear. As for track, my understanding is it's center of wheel to center of wheel on that axle, but I can't find anything authoritative about it. Would love peoples input/thoughts/experiences :)
Skyline model = R33 Series 2 GTST
Wheel Brand/Model = Rota Grids
Wheel width = 9.5 front and rear
Wheel offset = +30 (Running F&R)
Tyre size = 245/45/r18 (Front) ... 245/45/r18 (Rear)
Modifications to fit = Rolled front and rear
Rears are perfect, front rub slightly on inner mould with 3/4 lock, have lowered coilovers sitting slightly above tyre
Can anyone give a definitive answer on inner clearance on a 33 gts-t, with 18x9.5 +30 with a 235 tyre?
Have read the r34 gtr wheels are a bit close as is and these will sit 6mm further in.
Would just go the 18x9.5 +22, but am trying not to go nuts with poke.
cheers,
Jess
Edit: apologies, just saw above, how low is your car? will it scrub the inner if you dropped further?
Edited by JayTay
I have no mods to the height of the car ,stock suspension.
Nah not you mate, i meant SilverS2, info on his setup would probably help both of us, though if you put 9.5's on with no suspension work your car will look like shit.
+22 on a 9.5 will clear the coilovers at the front from what ive stuck in the calculators, but will have some serious poke without camber, lowness, roll/flare and most likely 225's.
Should be sweet at the rear with just a rolled guard. I think it works out to be pretty close to a 10" wide +18 in terms of fitment.
If anyone knows the final word on inner clearance it would be awesome if you could post it up, pictures would be good as well.
cheers,
Jess
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
