Wheel Sizes & Offsets For Skylines
18 x 9 +15 (fronts) and 18 x 10 +15 (rears) - pictures as promised :)
man only a couple inches off awesome get that shit slammed will look amazing
Hey All,
i have spent the last 45 mins going through all 78 pages of this thread lol and i cannot find any obvious combos with these sizes
I am looking to put these on my R33 GTST which has full height adj suspension but nothing else. I would like to avoid rolling the guards if I can but will if i have to.
19x9 +38
19x9.5 +45
Any feedback would be greatly appreciated.
yeh should fit, if anything might sit to far in but i think you'll clear all the necessary parts.
for whats its worth it wont look good but whatever suits you. :thumbsup:
i have an r33 g-st with stock 16" wheels.mycaris already very low ( wheels sit in the guards slightly ) im looking at buying rims 18" 8.5 wide and +45 offset front and 18" 9.5 wide and +45 offset rear... would they fit and look good, if not any suggestions to what i should get without any mods.. thankyou
they will still be roughly an inch inside the guards
for 9.5's on the rear, +30 is flush with guards anything more will require at least a roll
+~20 is nice, sits 10mm out and +~10 is perfect (looks wise)
a good measure for the fronts is to use the same offset on a rim that is 1/2" thinner as a 9.5+30 can have inner clearance issues (however these disappear at +25)
thankyou for your reply.. would i have scrubing issues with my car being so low?
maybe if i went with 8.5 front +35
9.5 rear +30 ???
im worried ill buy some wheels and they will scrub inside the guards.. i bought it like this and dont want to have to mod anything
Edited by rondog
18x9.5 +12 on 235/40 tyres, will this fit on 33 GTST?
Running about -1.5 deg camber on rear atm (probably same for fronts but not sure), don't want to go any more than this.
Only rear guards rolled currently but will do fronts ASAP
cheers :)
easy man.
i'm currently on 9.5 +17 all round with 225 f and 235 r
i dont run camber on the rears to fit, so i pulled my guards a lil.
front guards can be moved easily once they are rolled... i just push and pull mine depending on what rims i am running lol
fwiw i just ordered some 18x9.5+12 all round that will be wearing 235/40/18 NT05's... will post pics when they arrive
9.5 rear +30 ???
what look do you WANT and what rims are you looking at? :)
easy man.
Moar new rims? Been on the same set a few too many weeks have ya? :nyaanyaa:
Thanks for the advice, will hopefully snap them up tomorrow
plan:
18x9 +30 all round
225/40/18
stock 16's just tucking tyre on the rear and flush at the front,
anyone running a similar setup on their 32 gtst?
any modications i will need to do?
look for photos of r32 GTST with R33 GTR rims (17x9 +30)
Will give you an idea.
Here is a photo of 18x9 +30 (username: timr32gts)
im starting to think about getting new rims for my car, i have a 33 gtst with stock rims,
i think i will end up getting lenso D1R wheels in 18 inches and thinking 8.5 fronts and 9.5 rears,
not too keen on flaring the gaurds maybe a roll what off set do you guys think?
seen a lot of different numbers going around and it confuses the crap outta me, even used the offset calc, but still not sure if its right!
edit: also on stock ride height atm
edit edit: or should i look at something like 8 and 9's?
Edited by MatthewT85
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
