Jeremy - to give you an idea of the rears - here are mine in 9.5+25. IMO its pretty fat stance without being over the top.
Keep in mind my car is high as a kite - dropping it would tuck them in abit more if your not into them hanging out...
You can just see the chrome lips either side of the car in the first pic :D
Any on know if these will fit my R34 GTR, the description confuses me ( happens easily ) I know GTR's have pumped guards, but i don't have a wide body kit....?
http://www.ebay.com.au/itm/230759854482?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_922
let me know what you recon!
Looks tough!
What size tyres/ how camber are you running? Much guard work?
What about size/offsets etc on the fronts?
Looks tough!
Tires are 245/30/20.
Camber I am unsure of, but the guards have been rolled and ever so slightly pumped.
Fronts are 8.5 +25 - the need a 10mm spacer IMO
ok so money pending i maybe able to get some xd9s
they'd most likely be 18 x 9 all round, can get +20 or +30 offsets, what would the best way to go for a 33 gtst
same offset all round or stagger? and will it only take a roll of the gaurd to fit 9's on the front,
i have stock height now but prob will get coils later on...
please dont say get 9's and 10's...
thanks
10" wide wheels on a R34 GTR fit easily. They don't state the offset, that's what you need to know. Too small for a 33 or 34 Gtr IMO, most run 19x10.5 +15 to + 24
Skyline model = R34 GTT
Wheel diameter = 19" meisters S1 3p
Wheel width = 9.5" all round
Wheel offset = +36 all round
Tyre size = front 225/35 KU31 stretch & rear 275/35 nankangs
Modifications to fit = existing coilovers very low....
Fronts - extended studs, 5mm spacer (slight rub on internal plastics, have to harden Susp)
Rear - nothing atm...... internal of wheel just touches coilover when going up a high driveway & high speed cornering scrapes lil rubber but I will be puting a 2/3mm spacer and Gonna roll rears so these issues won't occur.....
If your Questioning why?? I got an awesome deal on meisters
Edited by Tough R34
Im about to put 18x9.5+22 225/35 on the front and 18x10.5+30 245/35 rears on my r34 gtt. Should be a VERY aggressive fitment. Thoughts?
Post pics when you get it done.
You will have a bit of poke and need some guard work I think
thanks
ok so i want to order wheels now, prob going to go the +30 route for 18 x 9 xd9's
everything will be ok up front?
^^^^ you will need a roll up front , might get away in the rear but i'd roll rear to be sure as you will most like dump the car in the future , might also need to run camber up front , if you have rolled your front and put those wheels on, the front gaurds will eat the outside wall of the tyres your running, get 18x 9 + 25 all round , staggered fitment isnt a must mate. Xd9's ftw
Thinking about getting some works with
Front: 17x8 Inch +36 Offset
Rear: 17x9 +36 Offset
Would i have any issues fitting these to a r33 gtst with stock suspension?
Fronts will look weak but rears will be ok
<p>
<br />
10" wide wheels on a R34 GTR fit easily. They don't state the offset, that's what you need to know.  Too small for a 33 or 34 Gtr IMO, most run 19x10.5 +15 to + 24<br />
</p>
<p>so i need to know if they are +15 to +24? mmm im trying it decide what to do wheel wise, currently running heavy 18inch nismo copies for my semi slicks and 20" work SC1's on the street. be nice to get a set of 19x10.5 ROH Modenas.</p>
<p> </p>
<div id="myEventWatcherDiv" style="display:none;"> </div>
18x9 +25 is going to sit out of the guard 5mm more than +30...
Also, if he rolls the guards the lip of the guard won't eat into the outside tyre wall. That is part of the reason you roll them.
18x9 +30 is the same size as 34gtr wheels and they seem to fit quite nicely on 33gtst's and 34gtt's
Edited by Mitcho_7
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
