That fit is prefect. I can't believe they fit that well with just a roll!
How do you think the rear would go with a 255/35? Probably need a pull to get it under you think?
I've got the 9.5 +22's all round on a 33 gtst, and i am running 265's front and rear. Only a guard roll and splash guards removed.
I'm running about -2.5 front and -1.5 rear.
No scraping/rubbning at all
Much poke with that size on the rear? Pics?
awesome fitment im looking at 9.5 +15 all round on 235/40/r18. So 2mm further in on the front and 8mm further in on rear. How much camber are you running and what work did you do to the guards.
Cheers
i'm running 225/40 on the front with -3 camber it scrubs when i drift but it will depend how low you go to notice scrubbing. On the rear i've got a 235/40 but i'm running 0 camber at the moment and have a pre existing flare of 25-30mm
I have trawled through this thread and it seems no one is running a very aggressive fitment on a ER34 coupe. Everyone has shitty offsets with little if any guard work.
I am purchasing Varrstoens 2.2.1 18" wheels. I was initially thinking 18x9.5+22 front, 18x10.5+30 rear, but after talking to a few people and looking through basically every post in the entire thread, I have decided it is not flush/aggressive enough for my liking.
What I am not sure of is if the guards are the same front and rear. If they are, I am thinking 18x10.5 + 15 all round. Only problem is it may scrub inside the guard on the suspension or arm, which I have no idea how much clearance I have. I can't really go 18x9.5 because the lowest offset they offer is +12 and that is (I am quite sure) not enough poke for what I am after. I plan on running 245/35 on the 10.5 or 225/30 on the 9.5. I have my guards rolled, I have the front liners removed, I have up to -2 camber from the coilovers and I will put camber arms on if needed. I don't really want to flare the guards.
I need some REAL opinions from people WHO ACTUALLY KNOW WHAT THEY ARE TALKING ABOUT.
Shoutout to nisskid for helping thus far.
Edited by voncina
pics???????????
just pull the guards... it's a cheap import, not a bentley
if you want to put 10+15's all round you are going to want to pull the guards or run a LOT of camber. depends on how much power you want to make really.... if it's more than stock then i'd look at pulling them reasonably far so i could run the rears a little flatter.
you will get away without flaring, but you'll definately need to pump all 4 guards.
it's only 10mm more than what i'm running on a 33, and 34 guards seem to sit abuot 10mm further out and i managed it pretty easily and it's flat enough to put down 300+ rwkw
here took some better ones.
18x9.5 +22 with 265 hankook z221's
rears have 7mm spacers
Looks mint! I cant believe the 265's sit like that on a 9.5 +22, especially on the front. I think when i get new wheels, ill run a thinner tyre on the front and dial out a bit of camber to help with tyre wear.
What was the reason for the 7mm spacer in the rear? Inner scrub issues?
rota grid 18x9.5 +20 all round,
Those should only sit out 2mm more than the +22, yet the front sits out a fair bit more than other photos. I know yours is a 34gtt, but i didnt think they was that much difference between fitment for 33gtst and 34gtt.
What camber are you running front and rear? Loving the colour/look of your car !
yeah funny how the fronts look like they stick out more than the rear, but i get that with mine also, its hard to get the rears looking more aggressive than the front on a gtst, you car looks very purposeful, show and go...
