Looks mint! I cant believe the 265's sit like that on a 9.5 +22, especially on the front. I think when i get new wheels, ill run a thinner tyre on the front and dial out a bit of camber to help with tyre wear.
What was the reason for the 7mm spacer in the rear? Inner scrub issues?
Nah no scrub, just had the space to push it out a bit more. If i bought these wheels new i would have got +15 for the rear
I have a 93 R32 GTST Type M, wanting to run 17x8 +28 rims (Work meister S1 2P). Any guard work needed? Will they clear calipers? Car has coilovers but very little camber adjustment as mostly stock suspension arms. Anything else I should know? Really want to avoid flaring/pumping/stretching guards at this point...
Has anyone got an example of the following on a 33 gtst
18x9.5 +27
18x9 +27
I saw the example last page of the white 33 with +22
How similar are these going to look because his looks amazing and exactly what I want but the rims only come in +27
Hey guys..
Just been searching through a few pages but yet to come across any confirmation..
Looking to see if the following will fit an R34 GTR,
19 x 10.5 +22
Cheers
I would have thought you would have scrubbing issues on fronts. I could be wrong though.
18x9.5 +27
18x9 +27
Assuming same width, yours will have 5mm less poke. Nothing to be too concerned about.
So to the eye it will pretty much look identical.
If I run the same width as him of 9.5 and same tires.
From what I read it will just need a roll on all corners
Yeah 5mm here or there won't make or break the look dude.
9 +27 on the front may not even need a roll, depending on height etc, but for the extra $100 you might as well get it done
Trying to make up my mind between 9 or 9.5
Not worried about having to roll the guards but
Are any other offsets available? You could run 9.5 +27 all round, fronts might have some inner clearance issues though
I'm just looking at Rotas rims because im a cheap ass.
They have a few of their grid range in +20 etc
I was looking at the BOOST 18 9 5x114.3 27
But I don't mind running 9 if the 9.5 has inner clearance issues.
9.5 and 9 mean the offset will be different, and for the sake of half an inch you are better off going 9's imo. Unless he specifically ran 9.5s with no issues.
9.5 + 27 = 9 + 22
Wider rim = less offset needed to poke the same amount, but then you get clearance issues. I want to run 10.5 all round but fronts will rub.
Edited by voncina
Because I don't want the clearance issue I would prefer the 9+27
Edit: used the calc and there is a 6mm difference between the 9.5 and the 9
So that means of the 9.5+27 is around 5mm difference to his setup
Then 9+27 will be about 11mm difference to his setup which will remove a bit of poke but still have a nice flush stance.
Will the fronts be flush with 9+27
Edit again: f**k I love this calculator finding so many good combos that are similar to his such as 9+20 only has a 4mm difference
lol kasko, if you want to see an example of how 18x9 +27 sits looks for photos of 33's with r34gtr wheels. They will poke 3mm more then those... Itll fit nice IMO
If you want to go 9.5 on the front, you have to go low 20's in offset for inner clearance, so you will get a bit of poke but as the pics on previous pages show it looks tough.
Look at it this way, the difference between 9" and 9.5" is 12.5mm. Therefore in the same offset a wheel that is 9.5" will be 6.25mm wider on each side of the wheel, than a 9"
Edited by Mitcho_7
Kasco just go 9.5+27 all round.
if you go back probably 12 months in this thread there's a pic of my car with 9.5+25 all round
Tried looking through to find it.
I guess you didnt have any clearance issues up front?
Rota also offer 9.5 + 20
Could go that if you were feeling a bit more ambitious
I keep looking at this but I dont want to have heaps of guard work.
Might test fit some 9.5 +20's when I lower the car to where I want
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
