ET is the short form of the German word 'Einpresstiefe' which literally translates as 'insertion depth'
What does Offset mean?
Offset is the distance between the hub mounting face at the back of the wheel and the wheel's centreline.
Offset is usually stamped or engraved into the wheel and is measured in millimetres of 'ET' [ET is the short form of the German word 'Einpresstiefe' which literally translates as 'insertion depth']
Positive Offset wheels have their mounting face toward the front face of the wheel. Most front wheel drive vehicles have positive ET wheels. Eighties and Nineties Volkswagen wheels are usually ET38.
Zero Offset wheels have their mounting face even with the centerline of the wheel and are by definition "ET 0".
Negative Offset wheels have their mounting face toward the rear of the wheel - powerful rear-wheel drive cars often have wheels with negative offset.
Hey guys just wondering if anyone can provide some insight. Currently selling my 17x9 CR Kai's and have been offered a set of Buddyclub Qf's (also 17x) for trade. The only thing is that they are off an evo and I can't fit trial fit them because the car is at the panel beaters. What offset would be best for my car? And how do I work out the offset of the rim? It has the number '26' stamped randomly in there, is that it?
skyline model = 33GTST S2
wheel diameter = 19
wheel width = F:9.5 R:10.5
wheel offset = F+12 R+22
tyre size = 235/245
modification to fit:
F - Almost complete inner guard removal, rolling of guards and relocation of a wiring loom.
R - Roll of the guards.
Ideally, I should probably take it up 2mm or something, on larger bumps / transitions in the road it can rub very slightly (mainly front)
Very slight rub at moderate lock on the front also.
Okay so I finally think I've found a good fitment for an r34 gtt.
Firstly, I test fitted one of my brother wheels which is 18x10 + 12 w/ 265 rubber all around on the car, and there was roughly 33mm of poke at the front guards, and 20mm at the rear.
I'm going to buy some +25mm wide fenders for the front, while pumping the rear guards out an extra 20-25mm as well.
Basically I want to run Varrstoen 2.2.1's on the car in the following fitment:
18x10.5 +30 at the front
18x10.5 +22 at the rear
Now I'm thinking of +22 at the rear in order to run a 265 width tyre, but can anyone shed some light on whether +15 with a 255 would look better?
Also need some advice on what width tyre to run on the front, and will i get any suspension issues (hitting suspension arms etc) on full lock?
FYI a 10.5 +22 will sit pretty much the same as a 10 +12
Edited by TM7GTR
To my knowledge, the offset didn't effect the width of tyre that can be run on a rim.. Just the width.. If you could elaborate on this if I am wrong, I would gladly appreciate the knowledge. I am running 245/40/18 on my 10.5+30's.
As for your issues, running a 10.5+30 on your fronts you will have major issues, and I don't even believe it will fit inside the guards without hitting the suspension arms/front strut. From where the stock rim sits, the new rim will sit 30mm closer towards the suspension, I would check that you have ample clearance first. IF you have clearance, you will have scrubbing issues on turning, you will most likely need to remove the liner from the front guard and reallocate the harness, and the guards would need rolling, that is a given.
Hey guys, anyone here run work emotion 11ft's on a r33 gtst? Im getting 9.5 +25 on 225/40 fronts and 235/40 rears on 18nch tyres anyone know if this woulld be all good? All the gaurds are rolled and car lowered. Any help appreciated plz
Offset doesn't effect the width of tyre that can be run on a rim, but if the rim is mounted closer to or further from the hub (+/- offset) surely the width of tyre would need to be taken into consideration?
e.g. you can run a 265 on a 9.5 with a high offset without scrubbing issues as the rim itself sits in the guard further, whereas a negative offset 9.5 rim would fill out the guard more and the 265 would likely scrub.
As for the fronts, I wouldn't have any problems at all with guard rubbing because +25mm wide fenders are slightly wider than r34 gtr front fenders if i'm correct?
Would it be safer to run 9.5 +12 and then use spacers to bring the mounting point further from the suspension arms?
The tyre that you want to run comes to personal choice, not down to offset. If you want your rim to sit in the guard nicer, you should get a better offset, not worry about what tyre to run, it should be your last issues. Get an offset that will fit, then get a tyre size to fit around that. I am running 245's because i will be poking about 5mm and need some stretch to bring it inside the guards, so I don't have to raise my car to get it above the tyre.
The issue may be inside the guard, rather then how far the guard pokes.. But I guess if you are getting a new guard, the interior lining will need to be removed anyway..
9.5+12 will sit fine inside the guard with pretty much no issues, then yes, you can use spacers if you like to bring it out to your desired poke, but if it is at the offset you want, you will be fine, I am running 9.5+22 fronts with issues only on full lock.
Make sure you get some pictures up when this is done, it sounds beastly!
Edited by voncina
Should fit fine with guards rolled and running those size tires
Yeah sorry man, I was just trying to explain what you said above... in a much more retarded way haha
Won't be done for a while yet, but it's gonna have aggressive fitment, new front, rear, and spoiler, and a respray.
feelsgoodman
GENTS THE MOST URGENT OF HELP IS REQUIRED......
im about to purchase some rays sebring, heres the details
18 x 8.5 +40 front
18 x 9.5 +45 rear.
will these FIT A 94 GTST.......................help me ladies and gents!
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
