Wheel Sizes & Offsets For Skylines
Steve you nailed it with fitment!
Should be putting in my order for the 18x9.5 + 22 rims this week or the next.
Cheers dude! I have to admit I was worried when I was selecting the fitment without test fitting anything, and buying them outright. But I was so glad when I saw they were almost 100% perfect!
Hope everything goes well for your car and fitment!
Has anyone ran 255 wide tyres on the front of their GTS-t ?
I'm currently running 275 rears and 245 front on R33 GT-R rims on my R33 boat. I honestly do not like any stretch (it's my OCD) and down the track just want to run 255 all round the car (tyres came with rims) for rotation etc..
I don't give a rats about hellaflush btw :)
I don't mind a bit of stretch when applied to the right car. You can't always just buy rims that aren't as wide because then you lose dish or the concave looks some people desire. That said, it looks so much better on an s-chassis than a skyline.
On the right car it suits. I think if I was running 265s on my 10.5s, it just wouldn't sit as nice. I don't see why there is need for discussion here - it all comes down to personal preference. If you don't like it, whatever. If you do like it, whatever. Everyone is going to have a separate opinion on the matter, but no one opinion is right. I dislike Work Meisters, I think they are disgusting looking rims. Doesn't mean someone else can't love them and put them on their car.
True words
Hey all just have a quick question to ask. 18*10 is the rim size. Have two offset sizes to choose from and they are +40 and +22. What tire sizes can I run with each offset size with as little camber as possible and a guard roll? I want to run as wide a tire possible on the rears. Will these fit in the rear of an R33 gts-t with 275 tires? If so where will they sit using the guard as a reference? If no what will have to be done to make them fit? .
Edited by Daboss
+40 will make the rim sit very far in, with big tyres it will most likely be rubbing on your suspension arms.
+22 will be fine for inner clearance, with removing the splash guards up front.
You will have to run camber front and rear, and will need a guard roll.
On the rear it will stick out with 275's unless you run a fair bit of camber, the fronts will be the same.
^ Yeah.
They are very weird offsets to have. You almost have both extremes on the scale, too far in and too far out. You would be better off running the +22 because the +40 will most definitely rub. Running 10's on the front will also present issues with turning on full lock in regards to the front liner. Your rims will sit around 10mm outside the guard on the fronts, and about 5mm on the rears. Decent fitment, but you will need to run camber up front and stretch the rears. :)
^ Yeah.
Thanks for the quick reply. you guys are the best!!!! :yes: The fronts are fine just the rears I am talking about the rears. The fronts are 235 40 18 +25 9 inch wide rim they will fit fine. Just the rears I wanted to know which offset I can run on the 10" rim to get the widest tire possible to fit with just a roll and minimal camber. What is the widest tire possible I can run on that wide a rim with those two offsets?
Edited by Daboss
i had 9.5 +22 with 265's all round, and on the rear i had 7mm spacers, and with that it sat flush, although i was running a fair bit of camber on the back.
With no camber it would have stuck out. And you'll have to roll the guards.
I'd probably run 265's on the 10 +22, should fit easy with a guard roll. Also 265's are easy to come by
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
