hes talking -4 degrees camber on the rear. and has R33 gtr wheels. which as you said are 17x9 +30, and wants to add spacers to add more poke. which in my opinion is unnecessary. but then, im not mexican.
4 degrees is a silly amount of rear camber......mine has mininal camber(not sure how much) but already very slippery compared to stock
thats what i was clarifying however -4 camber on standard arms as previously stated is impossible even with sacking it to the ground...
But your absolutely right camber in rear is completely stupid and doesnt help the car handle at all on the road
Hey all just need an expert opinion on a set of rear wheels I am getting. Long story short, I waited a little to late to get a set of wheels I wanted. Now the store only has rears available in a 18x10 +40. I know this will not fit, I just wanted to know what size spacer I would have to run in the rear in order to make it sit flush with the guard? I also have two offest sizes available for the front 18x9 +24 and 18x9 +30. Which of these offsets will sit flush with the guard with no mods needed. Also, with spacer calculation say the rim is a +40 will a 5mm spacer then make it +35?
what car are we talking about here???
yep bingo :D
yep bingo :D
Wow!!!!! Thanks for the quick response. So sorry was rushing forgot to mention its a r33 gts-t. How big a spacer would you say is just to big and ya might as well get a rim with the right offset. I was thinking of putting a 10mm spacer on back. or a 5mm. Will a 5mm be enough for the rear wheel to clear the necessary parts?
Edited by Daboss
depending on the wheel size you have on now i would say you would have atleast 25 - 30mm less clearance on the inside of the guard (closer to the strut) and about 30-40mm more poke towards the guard.
complete guess there on rim sizes that you have but i rekon a 10mm spacer will get you out of trouble just fine :)
depending on the wheel size you have on now i would say you would have atleast 25 - 30mm less clearance on the inside of the guard (closer to the strut) and about 30-40mm more poke towards the guard. complete guess there on rim sizes that you have but i rekon a 10mm spacer will get you out of trouble just fine :)
Right now I am stock. Just wanted to make sure I get the fitment right for the rims I am about to get. To let you know what they are front 18x9 +24 or +30
and rear 18x10 +40 with a 10mm spacer. How does that sound. Which offset should I go with in the front for a flush fitment no mods? I was leaning towards the +30
IMO its always best to test fit or measure to ensure fitment you want.
if you dont want to agressive on the front go the 18x9 +30 and then the 18x10 +40 and add that 10mm spacer. may need to just roll the inside lip depending on tyre sizes but should be all ok :)
with that ull need to do more than roll the inside lip unless ur planning on running some camber or a stretched tyre (or keeping it at stock height).
Edited by jjman
Hey jjman, what all will I have to do in order to get those wheels to fit in your opinion? To give you an idea with what I am working with the car has rear camber arms and coilovers front and rear. This is a r33 gtst. The rims I have in mind are 18x9 +24 or +30 in the front with a 235 40 tire and in the rear 18x10 +40 with a 10 mm spacer cause the 18x10 +22 are no longer available, with a 265 35 tire. In the front will the +24 be a better fitment and if the have another color available with the +24 in the rear will that be a better fitment? Are those tire sizez ok? Please someone help cause I am about to purchase these rims tomorrow and do not want to get them if they are too much trouble. Do not want to run ridiculous camber in the front or rear as it is a daily driver that will be doing some drag runs from time to time.
18x9+24 still won't poke. That is a close to flush fitment, it will sit about 2-3mm inside the guard. Safe. Running 18x9.5+22 and it is poking around 5mm with 0 camber, your offset is 8mm further inset.
With the 18x10+40 issue, a 15mm spacer will push it out to the same as the picture linked, which is my 18x10.5+30 245/40
http://sphotos-d.ak....154939089_n.jpg
If you are going to push it out ^ that far, and slam it, you will need to run stretch and rolled guards unless you want to look mexican.
Edited by voncina
Can't see the pic as I am to work, but I want to run a 265 35 18 on the back with as flush a fitment as I can get. I don't want any poke just sitting flush with the guard and lowered.
Interesting.
I was thinking about going 18x10+38 on the back of my 33 gtst. Thought i had plenty of room on the inside. What are you expecting it will foul on. Shock / Strut? Need to remeasure...
265 is a pretty big tyre, maybe drop a size but either way you will have to lip the inside of the guard
Interesting.
more than likeley foul on the strut. drop the offset to low 30s
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
