Just put the rims on only just fit, will be rolling the guards.
Question, how close are everyones tyres to the struts, looks a little to close???
Will 265 help that much??/
offset 40+
Thanks
No, the reason yours is so close to the strut is because you have an awful offset. I wouldn't run them until you get some spacers.. Chuck the stockies back on, roll all your guards, and push them out another 20mm or more (depending how mexican you want).
hubcentric BOLT ON spacers... but those rims may not have the capacity to run them, show us a photo of the inside of the rims before you go buying spacers.
It might work out cheaper to buy better fitting rims and sell them
Skyline model = R34GTT
Wheel diameter = 18"
Wheel width = 8"
Wheel offset = ?
Tyre size = 285/40/18
Just put some new rubber on.
They fit just.... can anyone point me in the direction of a good mobile guard roller?
Cheers
Edited by TTR34
Wheel width = 8"
Wheel offset = ?
Cheers
285's on an 8 inch rim?? Bit excessive there don't you think?
sif u buy meisters to run a spacer! you are not worthy :P
Haha - I know but ssssshhhhhh. When dealing with 20 inch Meisters the ability to pick sizes and offsets ceased in like 07 when they were discontinued. Now we all must deal and perserve with the choices others made in the first instance :( It's only my fronts I want to tease out a little more...
shits me i cannot get the 10.5 with the wheels I want. what does a 10.5 +30 translate to with a 9.5 inch rim. What offset should i get to match the same flushness as a 10.5 +30 wheel.
Skyline model = R34 GTT
Wheel diameter = 18
Wheel width = 9.5 +22 fronts, 9.5 + ??????rears
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
