shits me i cannot get the 10.5 with the wheels I want. what does a 10.5 +30 translate to with a 9.5 inch rim. What offset should i get to match the same flushness as a 10.5 +30 wheel.
Skyline model = R34 GTT
Wheel diameter = 18
Wheel width = 9.5 +22 fronts, 9.5 + ??????rears
10.5+30 = 9.5+17
Anything from +15-20 will look nice with natural camber from low.
Does anyone know if JZA80 turbo rims, 16x9 +50 offset will fit on the back of a R33 GTST.
I need some 16 x 9 rims for drag duties.
I was using R32 GTR 16 x 9 +30 with 255/50 16 Mickey T"s, but found that I needed too much height in the rear for the tyres to clear when launching.
Or any other 16 x 9 rims that will tuck in with the tyre setup.
Thanks
Just put the rims on only just fit, will be rolling the guards.
Question, how close are everyones tyres to the struts, looks a little to close???
Will 265 help that much??/
offset 40+
Thanks
looks fine..its not hitting ....so what are you worried about...dont matter if its 15mm or 2mm...clearance is clearance
"worked"... Save time effort and potential for damage and don't be a tight @ss
No damage.
Actually I didnt have the heat gun and gave it a smack with the hammer and cracked the paint a tiny bit.
But if you just user a mallet + heat gun you should be fine.
Every place that does it for $50-100 a corner says "50/50 chance paint will crack"
So I mean what have you go to lose?
Use a block of wood wrapped in a towel, a heat gun and a rubber mallet, I had mine professionaly done and they cracked the paint, me and a mate done his with the above mentioned equipment and it turned out fine with no cracking.
You need to do it in stages though.
Save the money for beer.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
