shits me i cannot get the 10.5 with the wheels I want. what does a 10.5 +30 translate to with a 9.5 inch rim. What offset should i get to match the same flushness as a 10.5 +30 wheel.
Skyline model = R34 GTT
Wheel diameter = 18
Wheel width = 9.5 +22 fronts, 9.5 + ??????rears
10.5+30 = 9.5+17
Anything from +15-20 will look nice with natural camber from low.
Does anyone know if JZA80 turbo rims, 16x9 +50 offset will fit on the back of a R33 GTST.
I need some 16 x 9 rims for drag duties.
I was using R32 GTR 16 x 9 +30 with 255/50 16 Mickey T"s, but found that I needed too much height in the rear for the tyres to clear when launching.
Or any other 16 x 9 rims that will tuck in with the tyre setup.
Thanks
Just put the rims on only just fit, will be rolling the guards.
Question, how close are everyones tyres to the struts, looks a little to close???
Will 265 help that much??/
offset 40+
Thanks
looks fine..its not hitting ....so what are you worried about...dont matter if its 15mm or 2mm...clearance is clearance
"worked"... Save time effort and potential for damage and don't be a tight @ss
No damage.
Actually I didnt have the heat gun and gave it a smack with the hammer and cracked the paint a tiny bit.
But if you just user a mallet + heat gun you should be fine.
Every place that does it for $50-100 a corner says "50/50 chance paint will crack"
So I mean what have you go to lose?
Use a block of wood wrapped in a towel, a heat gun and a rubber mallet, I had mine professionaly done and they cracked the paint, me and a mate done his with the above mentioned equipment and it turned out fine with no cracking.
You need to do it in stages though.
Save the money for beer.
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
