stretch is against my religion. But a 235 should see you right.
Otherwise camber is also a bad thing in a street driven daily unless you dont mind paying the $ that it costs in how much quicker you chew ur tyres out because of said camber.. but around 1 degree on the rear should see the rims n tyres fitting as well as minimal tyre wear from it.
Cheers man, Been a great help!
Hey guys.
I've got a R32 gtst coupe running factory 16 inch wheels 205/55/16. Looking at some 17x9 17p offset buddy clubs with 255/40/17 tyres.
What will i be looking at foul wise?
Cheers!
Edited by benji-nz
Hey guys, not very good with offsets and what not so was just wondering how a set of Work CR Kai 18x9.5 +20 all round would sit on an R33 GTST two door. Would it be better just to stick to my original plan of Work XD9's 18x10 +18 all around? Guards have been pumped and were previously accommodating 18x10 +12 no problem.
Edited by gtsttrk
Alex's old car yeah?
Definitely the XD9s, size difference isn't huge but they look much better than cr kais imo
Yeah mate Alex's old car, cheers that's exactly what I was thinking. Only reason I was considering the CR's was I could get them for a steal! Thanks for the input :D
hey all been searching for ages but can't find any for a R34 GTT, what i'm gonna be getting are some 18x9 but not sure on what offset, i was thinking about getting some so that the wheels sit a little bit outside the guards, if anyone can give me some advice it would be greatly appreciated!
You weren't looking hard enough haha. There are some on here, but far and few between.
Search for my post, I had 18x9.5+22 on the front and 18x10.5+30 rear. Front was 0 camber, rear was natural (around 1 deg neg) and car was slammed. Both poked by around 5-10mm: not too aggressive that cops want to pull you over, but still a very nice offset.
The equivalent to mine is 18x9+16 up front, and 18x9+11 rear. If you plan on slamming your car, run stretch or you won't be able to lower it enough. I had 225/40 fr, 245/40 rear, guards sat over the tyres nicely. Your front liner will more then likely need to be removed because epic scrapeage.
Have fun, remember to post up pics :)
Here's the wheels I've been building. Just got car from the painters so the N1 rocker panels are going on today. No roll front or rear and standard 1.5 degrees of camber front and rear. 265/35/18 on 18x10.5 et23 O-disk R-disk. I spent some time coming up with the specs for these wheels. It's down to mm of clearance but works great.
Edited by warp speed
perfect fitment for 32. Looks good
Hey guys,
Considering a set of Lenso Project E's from http://www.skylinesaustralia.com/forums/topic/420823-new-project-e-concave-wheels/
How would the 18x9.5+22's fit on 33 gtst?? I'm willing to roll the guards when i drop it in the near future
Thanks
Hey guys,
Thanks
If you are slapping those wheels on and lowering, roll guards is a must. If you have it stock height, I don't see any issues, maybe a slight scrub on the front guard. Front poke, rear tuck.
Here is my R33 Skyline GTS-t with 18" Enkei RPF1
Front 18X9.5 + 15. 235 tyre with -3 degrees of camber
Rear 18x10 + 38 (5mm spacer) 265 tyre with -2 degrees of camber.
I could just squeeze my fingernail under the rear guard
Looks clean mate! :yes:
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
