What's this gonna be like...
18x9.5 +22r
18x9.5 +30f
Tires are 225/40
On an r34 gtt
My calculator estimates the fronts will be out another 35mm and the rears 43mm
The car is lowered so a small amount of natural camber Bo no camber arms.
Seems Ok but what do the experts think?
Of course you are going to need to roll the rear lip and push the front guards back a bit but otherwise all good.
will be pretty good but for the love of god put some wider tyres on it.
9.5 inch rims take a 265. Get at least a 255 on there.
18x9.5 +22r
18x9.5 +30f
Tires are 225/40
On an r34 gtt
Hey guys,
I've had a read through this thread and found a few guys running close to what I want in regards to rim sizes but I'm not entirely sure on what tyres would fit
I've got a 98 R34 GTT
Rim size at the moment are 18", not sure what offset (they came with the car when I bought it)
For tyres I'm running 235/40/18 (Blue Streak) on the fronts and 245/40/18 (Eagle F1) on the rears
I've got my eyes on a set of TE37SL Black Edition
From what I've read up on I'm looking at going 18x9.5+22 at the fronts and 18x10+30 at the rears
Would I be able to run this rim and tyre size combo?
At the moment the guards are not rolled but I do have adjustable coilovers and camber kit (currently set at 1.5 neg on front and 2.5 neg at rears)
Thanks in advance
Hey guys,
Thanks in advance
Perfect.
Absolutely perfect.
Just remember to roll your guards, then enjoy wonderful offset - I had the same and it was immaculate. Front at 0, rears are around 1.5 and it was 5mm poke both sides.
tried searching, but didnt get a definite answer.
Will 25mm gktech spacers cover the stock wheel studs? or do I need to go 30mm? ie so factory studs wont protrude from the spacer.
my cars a 32 gtst btw
Edited by samoo
Hey guys
I own a 4 door gtst and am looking to fit Work Meister S1's
Rears 18x10 245/40/18 +20 offset
Fronts 18x9.5 225/35/18 +15 offset
I dont want to have to do to many modifcations, preferably just a good roll.
If it helps I'm running BC coilovers.
WILL THEY FIITT?? :woot:
within reason anything can 'fit', in that very liberal interpretation alot of people seem to be getting into these days.
In this case, well, not really if you are talking about an r32 and only rolling.
Otherwise it will also be a mexican stretched abortion...
It will also eat tyres and attract the 50 like a *insert witty comment here*
Hey guys
Hey guys
Actually these will fit with a little camber in the front tho on the back run a 235\40 and will be not much drama at all. You will need roll the inner lip tho all round
Edited by Frosty
Will these fit...
Car: R33 Coupe
Wheel: Rota Grid
Front: 17x9 +25
Rear: 17x9 +25
(Can stretch tyres if within reason, just want to know how they'll sit)
*Read about 15 pages and couldn't find what I was looking for*
Will these fit...
Car: R33 Coupe
Wheel: Rota Grid
Front: 17x9 +25
Rear: 17x9 +25
*randomly searching*
It'll sit 5mm further out compared to this:
$T2eC16ZHJG8E9nyfoT68BRUYR87Q2Q~~48_20.J
Tyres, don't know, 235 wide would probably be okay.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
