Wheel Sizes & Offsets For Skylines
It's not too big it's just big for a 9" rim and more expensive - so the only point that was being put forward is that it's a big tyre - which it is.
If the cars lowered can forget about 265s
Thinking bout some Cosmis Racing wheels on the R33 GTST, rolled guards already and inner liners removed
http://www.ebay.com/itm/Cosmis-Racing-MRII-Aluminum-Wheels-Rims-18x9-5-15mm-offset-5x114-HYPER-BLACK-/200953652670?pt=Motors_Car_Truck_Wheels&vxp=mtr&hash=item2ec9c565be
18*9.5 15 with 245/35 rear and 235/35 fronts
opinions on if it will fit and what colour would look good on a Silver R33 S2?????
not sure I like the chromed look to much.
Edited by AngryRB
I've got 19x9+25 235/45 on the front of mine, sits pretty well with rolled guards but camber from lowering makes the top tuck in making it slightly less aggressive, with some upper camber adjustment would be perfect, got 19x10 +25 on the back and needed quite a flair when got respray
Any pics of the rears mate
There's some in the 33 pick section, see how these work out, all I've got on my phone, rear guards had quite a bit of work with a slide hammer by painters, fronts were done by me with a guard roller until the flat lip around the edge of the guard stuck out about 30-35 degrees could easily fit 245 maybe 255 rubber under the front and 275 on the rear even if it's was lower, but can't get out my driveway
I've done a few hours of research but seem to have come up with mixed replies..
Will 18 x 9.5 + 20
18 x 9.5 +35 fit in a r32 gts4?
Is it possible with guard rolling, tyre stretching, and some camber? Or will I need flailed guards?
Cheers
Will 18 x 9.5 + 20
Cheers
Yes if your prepared to do the above anything is doable
both look decent, but doesn't necessarily mean it will on a skyline. e.g. you don't have as much wheel arch on a skyline as a 350Z.
You haven't even talked about offset either...
The first pic they come in 18*9.5 15offset
the second pic , can only find 17*9 22 offset
if you've seen simon's s14 drift car they look decent, not sure if the 17 would be aggressive enough.
Edited by AngryRB
Hey guys looking at getting a set of Work Emotion CR Kiwami sizes are front 18x8.5 +30 and 18x9.5 +38, anyone got pics of this on r33 gtst s2 and what are your thoughts on those offsets/staggered etc? any help appreciated.
18x9.5+15 is way too much for GTST guards without major work plus camber n stretch etc etc.
17x9+22 will work but need some mods to get to fit n will prob rub the fronts.
look like the AME's ?
http://nissansilvia.com/forums/index.php?showtopic=519512&hl=&fromsearch=1
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
