Hey guys great thread. I have had a look but would like some recoomendations as to what numbers to use on my R33 GTS-t. This car will be used predominantly on the track and I prefer 17" wheels (thinking of Rota grid, or P45R or something similar). Im also thinking of going with a staggered set up (9-9.5 rear and 8-8.5 front). I want to run some nice wide tyres also. Questions is, what do those who do track days recommend from their experience?
Cheers
Amir
Hey just want a quick answer. Going to buy a set of Lenso D1R's for my daily R33. Would 18x9 +32 (Front) sit flush in the guards
18×10 +22 (Rear) sit flush in the guards
Or what issues am I gonna get
Just like to hear some feedback to help me out.
Edited by WLD MAN
Assuming Gtst. Fronts will sit inside about 10mm, and rears outside about 15mm. This depends heavily on camber though. I have 18x10+38 which after resetting camber to 0 now sit flush, maybe the tiniest bit of poke, whereas previously looked like they had heaps of room.
12mm wider rim, so 6mm either side. But 8mm larger offset, so will sit in 2mm more than 18x9+32.
You'll also have clearance problems on inside with offset larger than around +25 with 9.5" wide rim.
Best if you learn how to calculate offset, or use a calculator on the net.
My recommendation would be to use 18x9.5+22 with 235s and roll guards to fit. Not too difficult or expensive and proven to be a good combination for 33 gtst.
Cheers
Amir
I went for a staggered set of track rims last year (17x8.5 +30 front and 17x9.5 +38 rear) but changed to a square setup this year (17x9 +35 with 255/40 tyres) for the increased frontend grip and being able to rotate the wheels around the car as they wear.
Similar to what i have done, just with 18's :)
  • Like 1
What's a good offset for Rota Grid Rs in 18x9.5 all round on a 33 gtst? Thinking +35 all round. Will only go as far as rolling my guards.
Cheers
I think heaps of people run +22 all around with little tyre. Might want to check front clearance before you go putting money down.
Did you notice any oversteer with the square setup?
Cheers
Amir
Agreed, you'll definitely run into inner clearance issues with +35.
Honestly, if you're willing to roll guards just get +22 with 235/40/18s and be happy. I didn't get 9.5 +22 and sometimes wish I did.
Im thinking of getting 17x9 +25 for my r33. The guys at Rota recommended this and said the widest tire I can run would be a 255. They also said I will have better clearance with +25 than with +35.
Does this sound right to you guys?
Cheers
Amir
  • Like 1
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
