Welcome!
Those sizes are fine, it's good enough for Nismo.
But, it depends on what look you are after.
Have a look here:
http://www.sau.com.au/forums/topic/311136-r34-gtt-wheel-register/
http://www.skylineowners.com/forum/showpost.php?p=2006109&postcount=78
Thanks Man! Great threads to look at!
If your doing more mods down the track lowering etc I'd go more aggressive
Open to suggestions! I am not really going for major mods at this point... sort of just getting used to the car :D But who knows!
If you want to "stance" your car, then yes definitely need more aggressive sizes and offsets.
I see... well, I think I will just go for the "regular" look for now. I will not lower the car too much in the near future (our roads are rubbish!)
Will a 18 9x5 +30 work well for the rears?
Yes.
G'Day! Well, it is done:
Work Ultimate Kiwami 18x8.5 +30F wrapped in 235/40/18 and 18X9.5 +38R wrapped in 255/35/18. Bronze with red caps and lugs.
Thanks for the pointers, everyone! I will put up pictures when done in about a week.
Carlos Ch.
Hello everyone. I am new to this page. Just bought my first skyline. I have a 89 r32 gts. I'm about to buy a set of wheels for it. I'm going to lower it after I get wheels and tires. Question is picking out the right size set up. Will 17x8 et25 work? Also what size tire should I go with then. Don't want to rub on anything. If that set up will not work can some one direct me in the right direction for set up that will work with out rubbing. Thanks guys
Are you using adjustable c/o's? If not and just using a sport spring and shock combo, you should lower it first to your desired ride height and go from there. Also remember that cambering in will change fitments too. For the question about an 8 wide with 25 offset, start at page one here on this page thread. You may change your mind on that size after reading more and seeing others fitments.
I will be using coilovers in the near future. It's just on stock suspension. I have looked through page 1-135 so far and I haven't seen anyone using +25. I'm not good with this type of stuff. I also didn't want a set up were my wheels stuck out past my fenders. So how do you think this set up would look on a gts? Good ? Bad? 17x8 +25 also size for front and rear tires?
Thanks again
17x8 +30 17x9 +35
Those are the usual sizes that fit.
Look up the offset calculator and then make measurements on your car to "see" how the sizes would sit.
Or, look up pictures of cars with R33 GT-R wheels (17x9 +30) and go from there.
Thanks for the reply. The only reason I was asking is because the wheels I want only come in those sizes. So you don't think those wheels will look right?
They'll be right. I run 17x9 (+25 or +22 cant remember for sure) and they are ok. They do not sit outside the fenders so your 8" wide rims should be ok
Amir
Well, after a little bit of an ordeal, the wheels are on.
Work Emotion Kiwami 18x8.5 +30 Front and 18x9.5 +38 Rear. Tires 235/40-18 Front and 255/35-18 Rear. No mods that I am aware of... yet again the car already had some aftermarket wheels (SSR, 17's) and since this is pretty much the only one here, I have no comparison point for suspension height. Guards are not rolled, I checked...
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
