Yeh :whistling: Nice car :wub: it
The black looks OK but I love the difference a bit of colour makes, I think the cars look different in a good way. Black looks more threatening and lighten them up adds a little class , well until you see the FR34K , haha
Smart plates and got the R34 in nicely :thumbsup:
First off, I don't know a damn thing about cars. At all.
But, I was wondering if 16 inch rims will fit on an ENR33 gts-4. I just bought these to replace some nasty rims.
205 / 65R15 are the original tires. They are on right now.
205 / 50R16 are the tires I want to put on.
I would say that since you have them on hand, go ahead and test fit them. Just by the look of them, it would seem you will not have any issues,
Hello All,
Skyline model: R32 GTR V-Spec (93)
Wheel Type: Weds Kranze LXZ
Wheel diameter: 19" (front and rear)
Wheel width: 10" (front and rear)
Wheel offset: +19 (front), +15 (rear) dish all around but more in the rear
Tyre size: 275/30/R19
Modifications: nothing....Front - spokes clear the front brembos by 1-2mm, full lock, no scrubbing. Rear - about 20mm clearance from top of rear tyre to underside of rear guard lip. Occasional scrubbing if I hit a pothole. Side wall of tyre comes past the rear guard by 3-5mm.
Hello All,
hey guys, i have an r34 gtt and want to get a set of grizzly import steelies but im hopeless with offsets and wheel sizes
they only come in: 16x8 -0 and 17x8 -0
16" is to small, so im gunna go 17", the question is will 17x8 -0 fit in my guards?
Try this offset calculator: http://www.1010tires.com/Tools/Wheel-Offset-Calculator
I would think 0 offset is way out there...
With that setup you are quite literally just moving the whole rim and tyre outwards by ~30mm. Honestly, I think it would fit but I would get your guards rolled as depending on the height of the car, it may rub. But if you are leaving stock suspension on I don't think you will have an issue. But you will be poking a fair bit, like 10mm outside the guard if you don't have aggressive camber setup.
(Form > function) If running a degree of camber or 2 is ok with you, run some stretch on the tyres and you could lower it to your hearts content (after rolling your guards) and you could pretty much have the chassis on the ground. It will be low and aggressive, if that is what you are after.
(Function > form) If you can go with a less aggressive offset (+10/+15) it would sit inside the guards flush, then you could run normal tyres.
For reference, I am running the same poke as the wheels you want to buy. I have stretched tyres on the front, and it lowered as low as it could go. And rears I have left decent sizes rubber on and left it a little higher.
I'm a bit hesitant about jumping into this discussion...
Remember the question is about an 8" rim. To get appreciable stretch on that you would need a 205 or 215 width tyre maybe which is smaller than a stock tyre. Each to their own and all, but it just seems a bit silly to me.
Hence why I said he should reconsider the offset as the tyre size is way too small IMO. Easy for me as I am running 9.5s.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
