I attempted to use search for this, but it came up empty.
I searched for a known size, still naught.
Don't think it likes numbers.
So........
Anyone know/ have pics of 18x10.5 +22 on a 32 gtr?
How close are we going to get to guards, suspension?
Justin's 32 gtr would be closest to these spec
http://www.speedhunters.com/2011/03/car_feature_gt_gt_justin_fox_s_r32_gt_r/
He's running abit of camber up front (more than 3 if i remember), he has a build thread on JDMST
If this is the wrong place to ask, let me know and I'll start a new thread!
Will 18x10.5 +22 with 265/35R18 fit an R32 GTR at standard height without issue?
Any modifications required?
What if I want to go lower in the future - say low enough such that the top of tyre is flush with the guard.
Wheels I am looking at are Work S1Rs, so offset is customizable in 1mm increments over a huge range.
Hi guys. Looking at buying a set of 18x9.5+18 F 18x10 +15 R to fit a 33 gtst. Gaurds rolled and pretty much stock hight. Interested in any advice, will they fit? Anyone else running similar spec and any input. TIA
Edited by GTST520
looks good, thanks for the link :thumbsup:
  • 3 weeks later...
sooooo im looking at ROTA grids.. (yeah yeah but im too povo for TE37's and the stockies are looking a bit tired)
which would fit better on a 34 GTT without flared or rolled guards?
18x8.5 +30 or 18x8.5 + 44?
just looking for a good fitment without any scraping/rubbing/stretching/modifying
(i've tried looking back through all the threads but i cant seem to come up with a simple answer which would fit)
edit:
just found a post from 2006 that was selling a set of LMGT4's which looked alright
(18x8.5 +30 and 18x9.5 +38 if anyone was wondering)
might see about upgrading the rears
Edited by lench
edit:
Go the 8.5+30. Shouldn't have any issues at all at stock height. Won't be an aggressive fitment at all though. Would be very stock looking.
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
