I'm currently looking at a new set of Rims for my R33 if anyone is interested in my staggered fit chrome 5 spoke style 19x7.5 front-19x8.5 rear (spacers for caliper clearance provided) with decent tread on them let me know. but to my main purpose of this post.
i am getting a set of Koya drift tech rims for my car. i will be putting slightly bigger brakes on my car eventually, if i get a set of 18x8.5 all round with a 30p offset does that seem like enough clearance for bigger brakes and also will they scrub badly on the front at full lock?? any advice would be great and no i don't want to go a staggered fit as an ex tyre fitter different width rims is just impractical for tyre life
Hamish or other knowledgable people.
Lot of talk here regarding 18x9+30 in the front of a R34 GTT or GTST. GTR Rims, sizing etc.
Lot of people run thin tyres on them, which 'fit'
Can you fit a 265 tyre on a 18x9+30 rim at the front of a 34 GTT?
Does it need guard work? Does it scrub? Etc etc.
Basically want the most tyre I can fit in there.
For bonus query, I plan to run about -3deg camber at the front, and have about 355mm center of wheel to guard.
/shake fist at all you tyre stretching people skewering results.
Let me know how it goes. I just bought track rims 18x9.5+22 255/40 and am yet to test fit. Would like to know what kind of issues (if any) you have with yours.
I mocked it up and it SHOULD fit.
that will fit. you will need to pull the guards a little, but not flare by any means
Looking for size and offsets to fit an R34 gtt 50mm rear fender wide body if anyone's accomplished this?
Thinking 18x11+18?
Also what's the best for pumped front guards? 18x9.5+20?
I'm probably way off.. haha..
Edited by Swole
ok... so i hate to ask this but i need some fine tuned answers from people who know more than me or have tried.
will these work on an R32gtr
18x10.5, +17 and +21
im currently running 18X9.75+20
the existing tires are 265-35-18 and im going to run them again.
i know it will be a little stretched but cmon not allot. and they will fit the guards a bit better without too much camber.
current setup looks like this.
from my calculations they will not get too mad.
in my eyes its gonna fit fine.... but when i look at 10.5 and r32... it dosnt seem like it should.
do you think i will need to roll the guards? i already know my inner liners will probably need to be removed as they DO scrub on hard cornering with the current setup. but the top of the tire will not actually move... hmmm
thoughts?
these are the comparisons.
First of all I think your current set up looks pretty good. The 265s will be not ideal but OK on 10.5 tyres but with virtually the same offset do you have enough clearance on the inside under cornering? Your outside guard might need a little massaging but not too much.
Ill get under the car and see if 10mm close to the strut will become an issue.
Their a front and rear set and the offset is what it is so i dont get to choose.
I do like the xxrs but their not what is staying on the car. A set has come up which are more my style.
Thinking 18x11+18?
Rears will be an eeeeeeeasy fit. A little inside the guards
Fonts will need a roll only
  • 3 weeks later...
Skyline model = R33 GTS-T
Wheel diameter = 18"
Wheel width = 9"
Wheel offset = +27
Tyre size = 245/40
Modifications to fit = Rolled guards
Hello, thanks to all the great information on here I have finally decided on my setup. IMO this is perfect, I really wanted to get the same width and offset rim all around so the concave would be the same. If anyone is interested they are Rota Boosts in Gunmetal. Here are some pictures.
Thanks :cheers:
Edited by CarterIvy
  • Like 2
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
