I'm currently looking at a new set of Rims for my R33 if anyone is interested in my staggered fit chrome 5 spoke style 19x7.5 front-19x8.5 rear (spacers for caliper clearance provided) with decent tread on them let me know. but to my main purpose of this post.
i am getting a set of Koya drift tech rims for my car. i will be putting slightly bigger brakes on my car eventually, if i get a set of 18x8.5 all round with a 30p offset does that seem like enough clearance for bigger brakes and also will they scrub badly on the front at full lock?? any advice would be great and no i don't want to go a staggered fit as an ex tyre fitter different width rims is just impractical for tyre life
Hamish or other knowledgable people.
Lot of talk here regarding 18x9+30 in the front of a R34 GTT or GTST. GTR Rims, sizing etc.
Lot of people run thin tyres on them, which 'fit'
Can you fit a 265 tyre on a 18x9+30 rim at the front of a 34 GTT?
Does it need guard work? Does it scrub? Etc etc.
Basically want the most tyre I can fit in there.
For bonus query, I plan to run about -3deg camber at the front, and have about 355mm center of wheel to guard.
/shake fist at all you tyre stretching people skewering results.
Let me know how it goes. I just bought track rims 18x9.5+22 255/40 and am yet to test fit. Would like to know what kind of issues (if any) you have with yours.
I mocked it up and it SHOULD fit.
that will fit. you will need to pull the guards a little, but not flare by any means
Looking for size and offsets to fit an R34 gtt 50mm rear fender wide body if anyone's accomplished this?
Thinking 18x11+18?
Also what's the best for pumped front guards? 18x9.5+20?
I'm probably way off.. haha..
Edited by Swole
ok... so i hate to ask this but i need some fine tuned answers from people who know more than me or have tried.
will these work on an R32gtr
18x10.5, +17 and +21
im currently running 18X9.75+20
the existing tires are 265-35-18 and im going to run them again.
i know it will be a little stretched but cmon not allot. and they will fit the guards a bit better without too much camber.
current setup looks like this.
from my calculations they will not get too mad.
in my eyes its gonna fit fine.... but when i look at 10.5 and r32... it dosnt seem like it should.
do you think i will need to roll the guards? i already know my inner liners will probably need to be removed as they DO scrub on hard cornering with the current setup. but the top of the tire will not actually move... hmmm
thoughts?
these are the comparisons.
First of all I think your current set up looks pretty good. The 265s will be not ideal but OK on 10.5 tyres but with virtually the same offset do you have enough clearance on the inside under cornering? Your outside guard might need a little massaging but not too much.
Ill get under the car and see if 10mm close to the strut will become an issue.
Their a front and rear set and the offset is what it is so i dont get to choose.
I do like the xxrs but their not what is staying on the car. A set has come up which are more my style.
Thinking 18x11+18?
Rears will be an eeeeeeeasy fit. A little inside the guards
Fonts will need a roll only
  • 3 weeks later...
Skyline model = R33 GTS-T
Wheel diameter = 18"
Wheel width = 9"
Wheel offset = +27
Tyre size = 245/40
Modifications to fit = Rolled guards
Hello, thanks to all the great information on here I have finally decided on my setup. IMO this is perfect, I really wanted to get the same width and offset rim all around so the concave would be the same. If anyone is interested they are Rota Boosts in Gunmetal. Here are some pictures.
Thanks :cheers:
Edited by CarterIvy
  • Like 2
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
