Wheel Sizes & Offsets For Skylines
On 27/02/2023 at 3:38 PM, 93soup said:
Recently bought a 33gtst s2 and looking for some wheels. I found a set of 18x9.5 et35 just wondering who else has run this spec and any clearance issues or mods needed?
If you searched this thread you would have found that out.
  • 3 months later...
Skyline model = R32 Skyline GTS-T 4-Door
Wheel diameter = 18
Wheel width = 9.5
Wheel offset = +38
Tyre size = 245/35 (This is a must...)
Modifications to fit = None, but it would be recommended to get some wheel spacers, I am thinking of running 2.5 in the fronts just to push them away from the suspension just a tad as it's a bit close for my tastes.
Stock suspension, fenders have not been touched what so ever.
  • 6 months later...
On 1/14/2024 at 1:25 AM, Adz2332 said:
Has anyone had the A disk on a r32 gtst with R33 gtst brakes on it?
I have A disk meisters with r32 gtr brakes on the front, clears the calipers no worries.
O disk rear.
Edited by WMDC35
O disk rear.
What offsets? Any pics mate?
18x9 +22, 18x9.5 +24, they're on a c35, a mate had the same size on a 32 gtst, but needed more camber and guard work than the laurel, pic maybe not relevant haha
Edited by WMDC35
O disk doesn't have as much curve in the spokes to get around the caliper.
Pay to check on the work site but you'll see certain sizes and offsets available on each disk.
3 hours ago, Adz2332 said:
Thanks mate!
I run 18x9.5 +11 O disc rear and 18x9 +18 R disc front. This is on a 33, not a 32 but I have no issue with clearance
not the best pic sorry
  • 3 weeks later...
general rule of thumb:
If you want stock-ish fitment,
8 to 8.5 +35 front
9. to 9.5 +38 rear
These are Nismo sizes for RWD Nissans.
From that baseline, you grab a tape measure an figure our where your new set of wheels will fit.
@Adz2332 please specify what car you have, what body panels, and what modifications you will be running.
GT-R owners like me have it easy, but RWD owners, have a bit more calculations to run.
You can obviously run "GT-R" sizes, which would be 9"+30. But that heavily depends on your preference.
This rant is completely ignoring any StanceNations specs/looks.
8 to 8.5 +35 front
9. to 9.5 +38 rear
Thanks mate.
32 gtst. Stock panels but don't mind pulling them ever so slightly as it hasn't gone to paint yet. Stock arms etc with coils.
I was hoping I could get any of the specs below to fit the front to
  • 4 months later...
Hey guys any recommendations for fitment for a stock 94 GTR R32
Want to order work meister s1 3p and would like a nice looking flush fitment. Plan to get MCA coilovers to set ride height etc. Just confused on offset, brake clearance etc.
Never purchased after market wheels so I'm a bit concerned since it's a long wait to order and I don't want to order the wrong specs.
brake clearance depends on spoke design
GT-R size I'd go 9.5 +15 or +12, and if you've rolled your guards, 10" +20.
People run 10.5 but I reckon that's too wide.
The other thing to watch in the meisters is they have different faces to cater for different brake sizes. eg. i run an 'R' disc on the front (biggest clearance for brakes) and the 'O' disc on the rear. it doesnt impact size or offset, its just the shape of the rim face that changes.
Yep I did some more research and found this out also. Still hesitant on ordering until I find the right fitment for a stock GTR r32
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
