Skyline model = R32 GTST
Wheel diameter = 17"
Wheel width = 8" front 9" Rear
Wheel offset = +42 Front +42 Rear
Tyre size = 235/45/17 Front 235/45/17 Rear
Modifications to fit: front requires 5mm spacers to give enough spacing with 235's
Hi guys,
I'd like to know if I wanna get rims for my R32 gts-t in 17 inch with 8" front and 9" rear So, what offset should I get to make the rims sit right to the outside of the guard without rubbing? (will lowerring the car too)
any pics would be good
Cheers
Ford
Quick Question Guys.
I have been reading over this thread and it appears that the largest wheel size you can put on an R33 GTR with NO modifications are: 18 X 10 +18 or +20
I just want to confirm that you dont have any clearance issues as far as with turning or anything like that. 10" wide wheels would be perfect for my build as I need to help with traction, but I just want to make sure that I am not going to have any problems turning or anything along those lines as I will probably be getting into doing road racing as well.
Thanks a lot for the info and the help guys. I do greatly apprecaite it,
-Sayajin
Wheel diameter = 18"
Wheel width = 8.5" front 9.5" Rear
Wheel offset = +37
Tyre size = 225/45r18
Wheel type = Work meister s1
Modifications to fit = i have coil overs and no inner guards
Will these fit?????????
Skyline model = R33 GTST
wheel type= advan racing series 1 tri spoke
Wheel offset = +35 Front +35 Rear
Modifications to fit: none
i was looking at getting some 18s for the line but im not shore what offsets to go any help would be great im looking at 18x8.5 front and rear with tyres probly 235x40x18. car has been lowered nuthing stupid tho and still has standard brake calipers etc i would like to have the offsets so that the wheels are close to the edge of the gaurd cos it looks funny when wheels sit inside the gaurds heaps so any one who can tell me wat offsets to run would be great
wheel type= work VS KF
Wheel diameter = 18''
Wheel width = 8'' 9''
Wheel offset = +34 front, +38 rear
Tyre size =235/40/18 front, 265/40/18 rear
Modifications to fit = none to stock height (till i lower it, then it will be rolled & flaired)
Ok, teh beast is an R32 GTS4.
Front wheels: 18 x8, offset 29mm.
Rear wheels: 18x9, offest 35 mm.
Tyres F & R: 235/40/18.
No mods to fit. However, once the car is lowered and a camber correction kit fitted the rear guards will need lipping.
Could be run lowered with excessive camber ( was when I bought it ) but that's dumb anyway.
@ subie: You'll be f**ked on the rears, mate. Guards will need lipping at least, judging by my car.
Dunno about the fronts but don't like your chances. I intend to change to 18 x 8 all round.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
