Okay so it has come down to the day of actually pretty much buying my rims.
Starting to get cold feet!!
18x9.5 + 22 like what Hectic is running
or be a little safer and go
18x9.5 +30
I CANT CHOOSE!
The +30 will be a little better for not getting police attention.
Would the guards still need a little roll even if I am running camber from my coilovers
I have some XT7s on order, 18x7.5 +35 fronts 18x8.5 +32 rear. Just wondering what size tires you guys recommend for a nice fit for these rims. I'm not a fan of stretched or balloon looks
What do you think of toyo proxie 4s?
I'm kinda a granny driver lol but I occasionally give it a squirt. My r32 is basically stock, just an FMIC an uped boost, at a guess 160ish KW
The kumhos, are they a soft compound? How much are they roughly?
Im getting some racing hart rims for my R32 GTR and want to know if they will fit.
They are 19x10.5 +15
Ive been told they will fit. Ive looked up the jap site for the rims and think they might be 19x10+15 tho.
Anyway will these fit under my car?
What mods will be needed so theres no probs?
I would be keen to get that checked. That is a VERY large rim for the 32gtr. 33/34 R's may be able to run them but I am under the impression the 32 guards are smaller then 3/4s. Can anyone back me up on this?
Found out they are 19x10+17
Trial fitting tomorrow then choosing the tyre size. Bloke reckons prob 265 max on there.
Will put up pics when fitted. Fingers crossed. Definately going to fill the guards. lol
Yeah, even 265's may be a sqeeze. I got 245 running on 10.5 and it has decent stretch, but not too excessive. 265 is the optimum size (I do believe) for 10's. Do 32 Rs come with 17's from stock?
I ended up swapping my CR Kai's for Buddyclub P1 Qf's. My only concern now is that I've gone from a +22 to a +17 and haven't had a chance to trial fit. Will they fit ok? Will I have an issue if I want to upgrade to bigger brakes in the future?
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
