shits me i cannot get the 10.5 with the wheels I want. what does a 10.5 +30 translate to with a 9.5 inch rim. What offset should i get to match the same flushness as a 10.5 +30 wheel.
Skyline model = R34 GTT
Wheel diameter = 18
Wheel width = 9.5 +22 fronts, 9.5 + ??????rears
10.5+30 = 9.5+17
Anything from +15-20 will look nice with natural camber from low.
Does anyone know if JZA80 turbo rims, 16x9 +50 offset will fit on the back of a R33 GTST.
I need some 16 x 9 rims for drag duties.
I was using R32 GTR 16 x 9 +30 with 255/50 16 Mickey T"s, but found that I needed too much height in the rear for the tyres to clear when launching.
Or any other 16 x 9 rims that will tuck in with the tyre setup.
Thanks
Just put the rims on only just fit, will be rolling the guards.
Question, how close are everyones tyres to the struts, looks a little to close???
Will 265 help that much??/
offset 40+
Thanks
looks fine..its not hitting ....so what are you worried about...dont matter if its 15mm or 2mm...clearance is clearance
"worked"... Save time effort and potential for damage and don't be a tight @ss
No damage.
Actually I didnt have the heat gun and gave it a smack with the hammer and cracked the paint a tiny bit.
But if you just user a mallet + heat gun you should be fine.
Every place that does it for $50-100 a corner says "50/50 chance paint will crack"
So I mean what have you go to lose?
Use a block of wood wrapped in a towel, a heat gun and a rubber mallet, I had mine professionaly done and they cracked the paint, me and a mate done his with the above mentioned equipment and it turned out fine with no cracking.
You need to do it in stages though.
Save the money for beer.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
