Skyline model = R33 GTST
Wheel diameter = 17"
Wheel width = 8" front 9" rear
Wheel offset = +30 front +35 rear
Tyre size = 235/45/17 front 255/40/17 rear
Modifications to fit = none, not lowered (would probably have to roll guards if lowered to far)
Nice and flush.
34 gtt. Definitely going to run a 235/40 now as I'm realising the front is going to be a tricky fit.
I'll just have to put up with it until I convert to wide guards :yes:
just run 235/40 all round.
remember that a good quality 235 is gong to give you more grip than a shitty 265... it's not all about the width.. I used to run 300+ on 235 nitto NT05 with great traction (well what you can call great for 300+ rwkw
also the fronts are an easy fit... just need to massage the guards and remove the liners... took me like 15 mins to roll the fronts for that size
hell no.
legal minimum for a 9.5" is 245 and 235 is within specs for many manufacturers....
this means it's tested not to fail
just dont want the sidewall collasping on me on a hard corner. I may have to get 245 to be safe then but how much bigger is the 245 than the 235 on the sidewalls "5mm"?.want little to no scrubbing issues
you aint gonna lose a tyre from a 235 on a 9.5"
I've happily driven a 300+rwkw car up mt buller road at 10/10ths with 235's on 9.5's
if i die its you to blame hehe, jokes thanks for the info.
Would be more likely to un-seat the bead than collapse the side wall. Not good either way though.
ill push with caution and get better tyres to compansate
a 235 on a 9.5 isn't going to unseat the bead... it'snot a stretched tyre.
anything that de-beads a 235 on a 9.5 would have done the same to a 265
http://www.nittotire.com/Tire/nt05#size
check that... the NT-05's that I used on the 33.
look at the 235/40 - it's approved by the manufacturer (in super litigious america) from 8.0 - 9.5
should end any arguments
Weekend teat fit showed that
18x9.5 /10 +15/20 has no chance on my 34gtt
Mad Mexican with no camber,
Hoping to have more luck with 18x9.5 +30 all round with 235/40.
Will stick out 35mm not 55, hopefully be able to make it work, unfortunately interstate so I have to commit and hope.
Weird how much 18x9.5 +15 stuck out on my 34. The tires were 235/40 and the top edge of the Tyre tread even stuck out past the guard. No camber and stock height but it was fairly gay looking. I should have taken a picture.
When u camber the wheels with adjustable camber arms, does it pull the top of the wheel in or push the bottom out, or does it pivot from the center of the wheel?
Edited by GH05T
centre.... but when you lower the car it cambers and tucks a fair amount naturally.
the guards on my care were pulled fairly aggressively, but not flared. the front guards are soft as... you can pretty much put them whereever you want
did you see the pics i posted 18 x 9.5 +20 at the back will be flush.If you want to have a bigger tyres to utilise the grip of a 9.5 then get a 30.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
