Can anyone confirm if 18x9.5+32 front and 18x10.5+38 rear wheels will fit an 1996 r33 gtst without any modifications, are these the widest you can go before you have to flare guards? if so how much wider can you go..
maybe wheel spacers?
cheers
cheers
That should be a completely safe fitment. Should sit inside the guards (for legality issuess) and shouldn't have any scrub issues, especially staying stock height. Run 235/40 fronts and 255/40 rears just to be sure. Make sure you post pics when you are done :)
Edited by voncina
hells no.
That will hit the rear guard lip and rub the front guards without doubt. Would need lots of camber and guard rolling to fit.
Will not be legal.
you are both wrong... lol
if you want low you will need to pull the guards a little for those sizes... but not much
and you wont need epic camber.
reference the pics at the top of this page
yeah i was looking at the 33 at the top, but i want to go for the out of the guard look, what will it be involved in doing that and fitting the new pair of ssr i just bought 18x9.5+32 and 18x10.5+38
hells no.
Will not be legal.
I am going to debate this..
If his car has no modifications then the stock height plus the small amount of stretch he will be putting on the tyres will miss the rear guard lip. I have 10.5+30 on the rear and if I raised my car I wouldn't need guard rolling at all. The only reason this fitment is illegal is because he will be running two different sized rims.
by that token if you raised your car it would stick out a bit too... remember they tuck in when lowererd
and becasue they are 18's
and because they are 10.5's
and becasue of the track increase
lol
who cares if it's legal... legal rims always look shitty
i figured some people just say it fits but they wouldnt do that to their cars. If it possible people should try test fitting and seeing if its possible or trust those with pics otherwise man you could serioslu get some bad offsets which you cant return.
17 x 8 + 5 front 205 tyre
17 x 10 + 5 rear 235 tyre
For show.
yes it gts
18 x 8.5 +30 225 tyre
18 x 9.5 +34 265 tyre
for go on road
17 x 9 +30 with 235 front and 255 rear for race but no pic
Edited by PaulosECR33
r33 s2 to fill the guards evenly do you go same size wheels all round. Or how much wider on the rear hypothetically if running similar camber.
planning to go 18 x 9 +21 front and 18 x 10 either +33 or +26 rear. Would prefer to go a little lower in offset but next up is 18 x 9 +9 which i think will be a reasonable effort to make fit and not scrub (ride height approx 335mm eyebrow)
Cheers
Edited by Pattey21
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
