Got R34 gtt with Bilstien slightly lowered coilovers
I want to get some Rota Grid R 17"
Plan to have 235s on front and 255s on the back
What offset/inch should i be looking at to be a nice fit ( no rolling )
http://www.rotawheels.com.au/wheels/rota-grid-r#!prettyPhoto
anything around +35 will be about right if you dont want to roll the guards etc. (tho it does depend on exactly the size of rim you intend to use.) 8.5 & 9?
Seriously though, dont hesitate to be open to rolling the rear guards. You can get some way nicer fitment and ride height if you do.
17x9.5+17 or 18x10+18
nope.
closest is 18x9+20 which will be a little sunken.
so options are:
18x9+20 with 10-20mm spacers
17x9.5+17 all round
17x9.5+28 fr and 17x9.5+17 r
17x9.5+17 fr and 18x10+18 r
18x10+38 fr and 18x10+18 r
18x10+ 18 all round
any of these will look good and pretty much all of these will require some form of fitment modifications unless you plan on running your car like an SUV
Does anyone have photos of how a 245/35 and a 255/35 sit on a 18x9.5 rim??
Can't decide which I want to run in terms of slight stretch. Pretty sure a 255 will just sit flush?
Need to know asap so I can supply one fitted to the body shop to pump my rear fenders to match.
255/35 Sits flush - have them on mine.
Hey guys, missed out on the buddy clubs! Now looking at some 17x9 +33 offset with 235/45/17 tyres? Also would these then fit over
the 324mm R33 GTR rotors (have the GKTech caliper Spacers for the 280mm disk)
Cheers!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
