fronts will be flush, rears will have some poke.
nothing that cant be overcome with rolling though
fronts will need guard liners removed
both will require minor stretch
Found a cheap but nice set of rims to put on my 89 gtst 4 door skyline
SQUARE Wheels G6 Model
17x9 +15 5x114.3
18x9.5 +12 5x114.3
I would love to fit the 18's but I am just wondering if I will have much problems making those fit. I dont mind rolling just dont wanna get into the pulling etc. WHATS YOUR THOUGHTTS?
17x9 +15 5x114.3
18x9.5 +12 5x114.3
to be brutal...
it's an 89 gtst, not an '09 R35... just pull the guards
It's an 89 gtst, not an '09 R35... just pull the guards
Just a quick one joeyjoejoe, when you had the 9.5 +22/+20s up front, did you just roll guards, or did you have to flare the guards slightly & ditch the liners too?
I had 9.5+12 on the fronts, but I removed the liners and pulled the guards a few years ago when I had 9.5+25's
once the front guards of a 33 are rolled properly you can just heat them up and push and pull them to where you want as they are fairly thin.
lol...
the initial roll was with a heat gun and guard roller.
but with subsequent sets of rims I have used a pipe, a baseball bat, the yellow pages and a jack, my bare hands and of course the guard roller. just depends on what's needed
basically the fronts are weak enough to be pushed in and out to suit. the rears dont go back in once they are done...
just be careful with the fronts and remember to check the panel alignment along the front door line and check the bonnet alignment BEFORE you open or close it
Going from the pics of yours when you had similar wheel dimensions to that, and had the greddy coilovers with good ride height (IMO), did big bumps ever make it bottom out wheel inside the wheel arch/liner at all? IE could your suspension have been any softer for that ride height or was that minimum stiffness? I've got softer suspension (SK bilstein/whiteline ones) and I wonder if I could get away with going lower.
I ran it on the hardest setting with 6/8's
front liners were removed and wiring loom relocated (just all pulled through and tucked up above the metal)
it scrubbed a tiny bit but nothing noticable
yeah fine...
daileyed it for like 4 years with those coilovers
i mean it's not "soft" and "comfortable" but really nothing that bothered me in the slightest
Do r34 gtr's accomodate wider rims at the front than a gtt with gtr front guards?
Just curious as this is how my 18x9.5 +15 CST's sit with 255/35's420643_10151201993838039_216824609_n.jpg
Not a very good angle, but this is the only shot I have at hand
very nice you finally got it done. The front GTR gueards are wider about 20mm more than the GTT.your wheels are sitting quite flush good fitment choice.
Hey guys,
Looking at a set of Rota Grids for my R33 GTS-T series 2 which is marginally lower than stock on coilovers (due to where I live/work I have to go up the occasional kerb and don't want to leave my exhaust behind so not going lower yet)
There is two sizes I'm considering and was wondering which would look/fit better without camber adjustment or guard modification.
Front 18x8.5 +25
Rear 18x9.5 +20
Or
Front 17x9 +12
Rear 17x9.5 +12
Won't go bigger than 18s as I already have back breaking, rock hard suspension on the stock 16s and roads here are somewhat crap. Also, tyre wise, I want to keep standard rolling diameter and don't want to stretch tyre, any suggestions?
If anyone has fit these sizes before, some pictures would be awesome.
Thanks
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
