  • 3 weeks later...
Thoughts on this size?
Rota Grids (concave version)
18x10 +35 offset
with 235-40-R18 and 245-40-R18 tyres
With the old tape measure there will be a bit of poke on the front, but im more concerned with what it might
touch under the arches!?!
http://www.willtheyfit.com/index.php?width=215&aspect=55&diameter=16&wheelwidth=6.5&offset=40&width2=235&aspect2=40&diameter2=18&wheelwidth2=10&offset2=35&Submit=Submit
^with the 235 tyres for the front
Cheers guys!
Anyone ever tried machining wheels to reduce the offset from say +22 to +27. This machining would be done on the inside hub where they would take out material to it. Koya Drift Teks and im willin to run a bit of a bigger tyre. If it doesnt work i guess ill have to sell and buy again.
it's possible as that's actually how drifteks are made from the factory, however you will also probably have to cut down the studs to suit.
It's also worth noting that the excess heat from the cutting will compromise the already compromised structural integrity of the rims
Heat shouldn't be an issue, as wheels and brakes do get very hot and Machining can be done slowly.
As joey said you will need shorter studs, or Wheel nuts with open ends. I had 6mm shaved off the front wheels of my beetle years ago....and didnt realise till I went to put them on, that the studs were now too long.
Let the machine shop/Enginbeer decide on how far they are willing to machine them.
Ok guys. Have gotten some Blitz Type 01 wheels in 17x9 with 22p offset. What would be the best width/height tyres to suit a R32 GTS-T standard guards? I believe 245-45 will fit the rears just, as there on atm (flush with the guards) but more concerned with the maximum width for the front, not fussed if the guard needs a little massage but don't want the insides to touch!
Also what tends to be the more popular sizes in 17 inch tyres?
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
