Skyline model = R33 GTR
Wheel diameter = 17 inch
Wheel width = (F) 9 inch (R ) 9 inch
Wheel offset = (F) 30 (R ) 30 ---> (F) 10 (R ) 10
Tyre size = (F) 245/45/17 (R ) 245/45/17
Modifications to fit = None
AFTER / BEFORE
1077752_10151761186247326_658129955_o.jp
Daniel - that's out of whack mate.
Front L+R and Rear L+R numbers should be pretty close to each other.
eg:
Front L = -01.85 R= -01.86
Rear L = -02.26 R= -1.99
So yeah fractionally different - not whole numbers apart
Edit: 3 degrees probably to much for the street. Fine for the track
Depends how much tyre wear you can bare.
Hey guys,
I have never been completely happy with how my 18x9.5 +22 rims sit on my car.
So I decided to call up the place who did the wheel alignment and get the specs for the camber that they put on it.
Below are the details
Front Left: -2.27deg
Front Right: -1.14 deg
Rear Left: -1.39deg
Rear Right: -3.69deg
Does this sound right? I always thought 3deg camber was something the fan boys did
I'm questioning if he actually gave me the correct info.
Looking at some whiteline camber arms to help correct this.
Edited by Sinista32
Okay awesome.
So they have bushes that allow you to adjust up to 0.75%
I was thinking of getting them for the front
And camber arms for the back to adjust the most.
What do you think?
Or should I be getting camber arms for the front as well.
front has no movement, but rear has a few degrees of adjust. camber adj blocks at the front will be fine, but you will need the arms to fix that rear. But that leads to the question, why is the car so far out at the rear? is this as good as they could get it? or is it just a dodgy alignment job?
I'm really unsure what happened.
I took it to a local Canberra tire place.
Seems very strange that they allowed it to be so different for both sides. Makes traction very strange in the wet. I was thinking with arms I could get it to almost flush.
Yeah rears shouldn't have more than a degree or 2 at most..3 on the front is fairly common, I run it but not on the back...and they shouldn't be that different side to side..half a degree at most...sure you haven't got a bent control arm...
It must look odd from behind your car...
For good handling you want r 2-3 on the front and 1-1.5 rear...for good looks you want to wear a dress and heels..
AFTER / BEFORE
needs more low!
:thumbsup:
  • Like 1
Hey guys,
Rear Left: -1.39deg
ouch!
This is on the money
this is a little too much on the rear as far as static camber is concerned in the rear regarding traction and handling.
if you come up the coast i have a guy that can do your car ;)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
