Hey guys,
Been looking at maybe getting some Touchdown TD136 rims from Cartel for my 33GTST.
How easily could I fit (F) 18x9.5+22 ® 18x10.5+25??
Also, does anyone have any of these rims on their car that they have a photo of??
Cheers all.
Ok, I've since found out only the 18x9.5 +22 clears the brake calliper in the Varrestons on the front.
Might be a bit too aggressive fit
Hey mate, are you saying the +30 option for varrstoens WONT clear the brakes on the front?
I was thinking of going 18x9.5 +22 rear and 18x9.5 +30 front as the fronts poke a bit more and im not really after that.
This is on a 33 gtst btw
Hey guys,
Cheers all.
I have pics on the last page of 18x9.5 +22 (-2 camber stock guards) 18x10.5 +30 (0 camber slight pump/flair)
Yeah, it doesn't clear the calliper according to the guy from Varrstoen
HELP OFFSET EXPERTS HERE:
Im trying atm to work out how far the wheels i am looking at buying , will stick out from my guards on my R34 GTR
Currently i have 18 x 10 +22 and looking at buying 18 x 9 +10 from my calculations the +10s will stick out .5mm less from the guards than the +22s .
Basically got the width of the rim 9 inches x 25 mm = 225 mm give or take and halved it for zero offset = 112.5 mm minus 10mm offset = 102.5 mm
10 inches x 25mm= 250mm = 125mm 22mm offset= 103 mm
Can anyone confirm this ?
Thanks
Edited by NISSAN GTR
Plenty of examples +22 fronts getting around. It's too much poke if you like driving your car anywhere.
As for the rears not sure. But last seems quite aggressive.
Cheers guys. It probably is a bit aggressive for a daily, so I think I may have to reassess my options.
Would I be correct in saying (F) 18 x 9 +30 ® 18 x 10 +35 would fit ok?
That will sit inside the guards, and I hope like hell it'll clear your suspension on the rears.
Sitting a fair more inset then stock, why not just go 18 x 9 + 30 all round, and get spacers if need be?
Edited by voncina
yeah man, 18 x 9 +30 all round works nicely. I understand you wanna go bigger on the back, but if you keep em the same your can rotate your rubber. even just go a 255 on the rear and 235 on the front.
You wanted 19s, couldn't get them, so decided on 20s instead. This says a lot about your personality...
Look think what you want about me I don't really care.
The reason I got 20's is cause I wanted that style of rim and I was told I couldn't get them in 19's.
so I hit 20's at the same price as 19's so I'm not complaining.
R32 gtst 2 door
Advan RG2's 18x9 +29 all round.
235/40 Sumitomo's (minimal stretch)
Suspension lowered to minimum legal height ( pretty high )
Front guards untouched, rears slightly rolled but wouldn't need to be.
Rims sit flush with guards, perfect fitment.post-116191-0-24551100-1379064184_thumb.jpg
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
