R32 gtst 2 door
Advan RG2's 18x9 +29 all round.
235/40 Sumitomo's (minimal stretch)
Suspension lowered to minimum legal height ( pretty high )
Front guards untouched, rears slightly rolled but wouldn't need to be.
I hate you. I was watching these on eBay and had offered him cash when he told me they were sold. Dude had them on his Evo yes? They look great!
Edit: If you ever decide to sell - me first!
Edited by colourclassic
R32 gtst 2 door
needs moar low
  • 3 weeks later...
Opinion time. Deep dish rims for an r34 gtt. 18 inch or 19 inch (the rims look smaller with big dish)
18's would require pretty low ride height to achieve stance.
Going to be running 10-10.5 width at the front, and 10.5-11 at the rears.
Tyre size = 225/40/18
Lowered= yes, on king lows/bilsteins. not slammed.
Camber = whatever is possible with the stock eccentric bolts and arms. Not interested in mega camber.
Should be fine. Keep in mind rolling guards done properly will have no negative impact at all
Skyline model = 1996 R33 GTST
Wheel Brand = Volk TE37
Wheel diameter = 17"
Wheel width = 9"
Wheel offset = +22
Tyre size = 235/45/17
Modifications to fit = None (front wheels lightly nudge front bar at full lock, otherwise fine)
Hi mate,
Just wondering if you managed to do anything to fix this?? Was it much of an issue?? Looking at doing exactly the same for mine =)
Cheers!!!
Hi everyone!
Car: 1998 R33 GTST
Wheel brand: BBS LM replicas
Wheel diameter: 19"
Wheel width: 8.5 F, 9.5R
Offset: +20
Mods to fit: Fronts needed a 3mm spacer(spokes rubbed on the NISSAN writing)
Rears sit outta the guards still, the guards have bee rolled I think. Is there a way I can somehow "pull" the rear guards out by a couple of mm so they fit??
The only problem with running those sorts of widths on the fronts on a gtt is the lack of guard. I had 9.5+22, and I had to remove the front liners for scrapage problems - and they sat completely flush with the guards. Now the issue here is, with a wider tyre, and non mexican spec, you will need a large offset, which you can't do as it will eat your suspension. I can't remember how much clearance I had with mine on, but I don't think there is much room for movement.
To get 10.5 to fit up front you will need something like +10 offset, 245/40 or less tyres, pumping guards, big camber, etc. Cause it will look mexican as fark with no camber.
Rears are 10.5+22 with natural camber and they sit nicely on the guard.
Rears shouldn't be out of the guards on those specs are u stock height? What size tyre?
Tyres are 265 35 19's
Car has tein coilovers, so it's lowered but not to excess....
Guards have been rolled a little(stuff all) but I can see where the tyres have scrubbed the guards on occasion :/
I will try and post photos(not working for some reason)
Edited by DGTS-T
265 is a big tyre drop down a size still well within legal and should fix the problem I think
I have gtr front fenders, and the rears are pumped and rolled +40mm.
Currently running 18x9.5 +15 all round.
Depenging on how much extra poke you want will depend the offset obviously.
I would go 18's, because of the possible slammage. 19's fit the wheel guard better, but also limit how low you can go.
Anyway 10.5+27 is essentially the same fit as what you have now, so depending how wide you want to go. I am not familiar with GTR fenders, but I believe they are around 20mm wider than GTT.. How wrong am I? Based off 20mm wider, I would go 10.5+15, which is 13mm more poke then what you have now.
On the rears... 40mm pump. Oh this is going to be sexy.
You could go 18x12+0? Or 18x11-12. The 11's are going to give dish all day, all week, probably most of next month.
Needs pictures.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
