Hey guys new on here ive been looking through here n still unsure of what offset to go, i have a series 1 r33 and i want to put on rota gridRs 18x9.5 but dont want them to hang out too much needs to be legal but still look good, will roll gaurds if need be
Yeah but on an 18x8.5 wheel running street rubber, wouldn't go wider than 255. 245/40/18 would be a good size (can get Sport Maxx for $200 in that size).
Sorry forgot the 8.5 width mentioned.235-245 max or it will look like a muscle car :)
Between +20 and +25, roll all guards and run 235 or 245 tyres
job done
Rays volk gtc with Federal rsr.
Skyline model = 32 gtst
Wheel diameter = 17
Wheel width = 9
Wheel offset = +35
Tyre size = 235 front 255 rear
Modifications to fit = front: minor lip and roll of guard, Rear: rolled guard as hard as i could, just fits.
too big, too wide, tyres too small, too much track increase, cops don't like skylines
if it looks good it's illegal, if it looks shit it's legal... gtst lyf bro
  • Like 1
best size to run on a 9.5... cheapest size so can get better rubber and looks good. still enough for traction and decent rubber choices.
unfortunately while it is WITHIN specs for most decent tyres, it is 1 size too thin for ADR's
Wheel diameter = 17
Wheel width = 9
Wheel offset = +35
On the ground it looks like:
Thanks, the old 32 gtst wing is good. Heavy though.
And im loving the wheels, but i have good tread on my old ones, so im saving the new ones for trackdays and dressing up for friday night etc.
Hi all,
Will these fit 1990 R32 GTR ?
Advan RZ-DF 19x10.5 +15
Badly want 19 inch but happy to
go down in width to 9.5.
Guards already rolled.
Any advise greatly appreciated.
Thanks
http://www.yokohamahk.com/products_detail.php?id=74
Hi all,
Thanks
Tyre size 265/30/19
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
