how would 17x10 38 R with 265/40
17x9 22 F with 235/40 fit?? any scrub on cornering?
would I have better handling and comfort over the bumps with this combo compared to 18x9.5 15 with 235s all round? I have rolled guards and want it to be flush or close to it.
Edited by AngryRB
hey guys.
at first sorry for my bad english...i´m from germany and have a question about new rims on my r33gtst...
will 8,75j x18 et20 front and
9,75j x 18 et20 rear
fit? tires are 235/40r18 front and rear.
or should i take the rims et35 in the front?
i only want to roll the fender on the inside ( in germany we say "bördeln" )....but dont want to pull the wheel housing...
http://www.japshop.co.uk/acatalog/XXR-527-18-INCH-ALLOYS.html%C2'>
greets from germany..and i hope you can understand me... ( where do i find the thread about introducing me ? )
hey guys.
Yes, 18x8.75+20 front and 18x9.75+20 rear will fit. It will be nicely inside the guards, only a roll is neccesary. Roll is where the sharp edge on the inside of the guard is pushed up on itself to create a soft curve - so it doesn't chew your tyres.
Pump means pulling your guard out to fit bigger rims or larger offset. I don't think you want this.
thanks for your answer...you understood me :)
how safe is it, that it will fit without scratching and so on?
hmm i cant edit...
anyone running 18x10 +15 at rear / 18x9.5 +15 at front on er34 gtt? will i need spacers?
On a 33? I ran 9.5 +13 and 10+11-15 can't remember. Just depends on rim style for front brake clearance
yeah, similar but 34 got more clearance i think, what rubber r u running on? 235? or 225? lol
Edited by enka
Hi peeps, the opportunity has come up to obtain a set of cheap 18s, 18x8 +35 for the front and 18x9 +33 for the rear
They will be fitted to my mrs r32 gtst, will this offset be too weak and sit too far in the guards? Thanks
whats the widest tyre you can go for a 17x10 38offset on r33 with rolled guards, im after maximum traction..
I have 18x10 +38 with 265s. Easy fit with rolled guards. Was thinking of trying to squeeze 285s in there when next due for tyres if I still have these rims.
Edit: stuffed up pic attachment...
Edited by M@&k
depends how low, how much roll/flare, how stiff etc
i'd say 265 will be the limit unless you really push the guards.
pump the arches and 285 wuld be possible
flare and the sky's the limit
Hey guys looking at getting a genuine set of nissan wheels but I know I'll have trouble with the offset, I want to know if it's worth getting, any and all help is appreciated.
Vehicle: R33 series 2 GTST four door
Rims: 19x8.5 +50
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
