Hey guys, thinking about getting some xd9's for my r32 gts-t, just wondering if I should go 18x9 +20 on the front and 18x10 +18 rear. There is 18x10 +38 rears but I'm not sure which one to go with. My cars pretty low so it has a fair bit of camber on the rear. This is the stock 16's on the rear. post-133055-13992801246113_thumb.jpg
Hey guys, anyone know if 8.5 +35 offset Koya Drifteks will clear the front brakes on a R34 GTT?
They should do, as the standard wheels are 7.5+40. Not going to say definite yes, but if you are going drifteks, get a better offset than 8.5+35. Go for something like 9.5+20, more concave and aggressive look.
Edited by sleptema
I tested them quickly with the 15mm spacers I had on, and they stuck out the guard around 20mm.
The reason for changing is I'd rather run rims without spacers, and prefer my rims sitting close to flush with the guards but not hanging out like some Mexican gangster's car :)
Caliper clearance was all I was really concerned about but it sounds like they should be fine, cheers guys
Dude, if they are sticking out the guards that much I don't think you have the right specs. I got 9.5+22 on my fronts and it was only JUST outside the guards, maybe 5-10mm. Even with 15mm spacers yours shouldn't be that wide...
Hey guys, just wondering if these will fit my 33.
XXR 536
17 x 9 + 30
17 x 10 + 26
Yeah, but the rears will poke 10mm+
Flared guards are needed, or slight camber and stretch.
Rolling is needed all round unless you want 4x4 spec.
Edited by sleptema
Thinking of getting LMGT2s for my GTS-T. Only ones for sale near me are white. Would white wheels like that look good on a black R32? I usually go for like metallic colors....
Why are you asking for our opinion? If YOU like them then YOU should get them. Who cares what everyone else thinks, our cars are a reflection of ourselves.
I'm guessing because he's not sure if they'll work with a black car having not seen before. Aside from being able to test fit, it's not always easy to tell if it will look good. I thought it was a fair question.
In my opinion (take it or leave it), white wheels work best on cars with solid colour (i.e. not metallic), black, white, or LM blue as on special edition R33 GTR. Google image search also helps.
I live in the US where there are literally no skylines. I have no idea how this will look since the only car i've seen is my own and i can't find a pic of it on google. I just want to make sure it will look good in person, I want to find silver wheels but I can't right now and am debating if I should buy these ones now because they are in immaculate condition and I don't want to pass them up.
Thanks. I tried google image search but seaching for 'white wheel black skyline' doesn't seem to work very well, lol.
Driftek's dont change the amount of concave on the face no matter what the size... they just have more material on the inside and deeper holes lol
that's how they are now able to offer custom offsets
That's the problem with 'copies' eh?
not specifically... just comes down to rim design
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
