Welcome!
Those sizes are fine, it's good enough for Nismo.
But, it depends on what look you are after.
Have a look here:
http://www.sau.com.au/forums/topic/311136-r34-gtt-wheel-register/
http://www.skylineowners.com/forum/showpost.php?p=2006109&postcount=78
Thanks Man! Great threads to look at!
If your doing more mods down the track lowering etc I'd go more aggressive
Open to suggestions! I am not really going for major mods at this point... sort of just getting used to the car :D But who knows!
If you want to "stance" your car, then yes definitely need more aggressive sizes and offsets.
I see... well, I think I will just go for the "regular" look for now. I will not lower the car too much in the near future (our roads are rubbish!)
Will a 18 9x5 +30 work well for the rears?
Yes.
G'Day! Well, it is done:
Work Ultimate Kiwami 18x8.5 +30F wrapped in 235/40/18 and 18X9.5 +38R wrapped in 255/35/18. Bronze with red caps and lugs.
Thanks for the pointers, everyone! I will put up pictures when done in about a week.
Carlos Ch.
Hello everyone. I am new to this page. Just bought my first skyline. I have a 89 r32 gts. I'm about to buy a set of wheels for it. I'm going to lower it after I get wheels and tires. Question is picking out the right size set up. Will 17x8 et25 work? Also what size tire should I go with then. Don't want to rub on anything. If that set up will not work can some one direct me in the right direction for set up that will work with out rubbing. Thanks guys
Are you using adjustable c/o's? If not and just using a sport spring and shock combo, you should lower it first to your desired ride height and go from there. Also remember that cambering in will change fitments too. For the question about an 8 wide with 25 offset, start at page one here on this page thread. You may change your mind on that size after reading more and seeing others fitments.
I will be using coilovers in the near future. It's just on stock suspension. I have looked through page 1-135 so far and I haven't seen anyone using +25. I'm not good with this type of stuff. I also didn't want a set up were my wheels stuck out past my fenders. So how do you think this set up would look on a gts? Good ? Bad? 17x8 +25 also size for front and rear tires?
Thanks again
17x8 +30 17x9 +35
Those are the usual sizes that fit.
Look up the offset calculator and then make measurements on your car to "see" how the sizes would sit.
Or, look up pictures of cars with R33 GT-R wheels (17x9 +30) and go from there.
Thanks for the reply. The only reason I was asking is because the wheels I want only come in those sizes. So you don't think those wheels will look right?
They'll be right. I run 17x9 (+25 or +22 cant remember for sure) and they are ok. They do not sit outside the fenders so your 8" wide rims should be ok
Amir
Well, after a little bit of an ordeal, the wheels are on.
Work Emotion Kiwami 18x8.5 +30 Front and 18x9.5 +38 Rear. Tires 235/40-18 Front and 255/35-18 Rear. No mods that I am aware of... yet again the car already had some aftermarket wheels (SSR, 17's) and since this is pretty much the only one here, I have no comparison point for suspension height. Guards are not rolled, I checked...
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
