Where is it scrubbing? It shouldn't be with those tyre sizes. The offset seems a bit high, might be scrubbing the front part of the plastic guard cover (if you're running high caster).
FYI I'm running 275/35/18 on 18x10+20, just touches the bit where the bumper is mounted to the guard (rolled guards). I could just raise the car to stop it :P.
  • Like 1
Quick question:
Will 18x9.5 +23 fit the front of an R33 without rolling or removing the splash guards? Looking at running either 225/40 or 235/40.
I've got no issue with rolling the rear guards but I don't want to mess up the front. Car sits with about 2-3cm between tyre and arch so not super low.
Currently running 18x9 +30 with no scrubbing at all.
Quick question:
Yes.
I don't wanna mess with the guard liner/front guards because a) it looks shit when it's missing and b) shit gets into the quarter behind the wheel. I'd rather just leave it untouched.
You are just rolling the lip on the fender.. Not missing the plastic lining... There are almost no downsides to getting it done.
Meh... bin it
Hey guys, im in the market for new rims and im a newbie when it comes to offsets so ive come to you guys!
My 33 has not had its guards rolled and sits at a pretty well standard height for the moment but will be putting some BC Coilovers in at the same time or shortly after i get wheels!
wanting to put the following on and Id like to know if i can run them safely without any scrubbing and to clear the struts and calipers and to not be sticking out the guards too much! (or is that too much to ask lol)
Tyres 235/40/R18 all round
Front : 18x8.5 or 18x9.5 + 22 to + 35 (roughly)
Rear 18x9.5 +22 to +30 (either or in between)
im after the most aggressive deep sort of look on my car, so any reccomendations and or opinions would be great!
looking at getting some varrstoen Es3's or Es6's or some Rotas..im too undecided there all so good!
Cheers!
Front : 18x8.5 or 18x9.5 + 22 to + 35 (roughly) go at least +30-22. Will need rolled guards. Varsstoen have low disc so I'm not sure they will clear calipers.
Rear 18x9.5 +22 to +30 (either or in between) will be fine, a little poke.
  • Like 1
So I think I've finally decided on a wheel size that I want for my R34 gtt 18x9.5+20 all round. (Now just need to find some BBS RGR's)
The thing is, I wanted to go with the same tyre size all around too, I couldn't find anyone or anything on the forum, but has anyone run 255/35 on the fronts? Closest I've seen was 245
Edited by tiddyd
Plenty of people have but you would be better going with a higher quality 235/40 if its a street car as it will grip just as well and will be lot easier to fit. Unless you are running 400kw or something crazy
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
