So Nizmo Man just answered your question. As long as the mathematical rolling circumference is identical, width DOES NOT matter. I had a guy turn blue in the face trying to tell me width of tire will affect the system. Big myth. Even the smallest difference in outer diameter circumference won't be noticeable to you or the computer but eventually will wear down the mechanical aspect of the differentials and/or transfer case. Largest problem of a staggered offset on awd is the tires. It's extremely difficult or near impossible to find a front that rolls the same as the rear. Mix matching tire manufacturers has sometimes worked but the time and research needed to find such a match is ridiculous.
ok, cool.
so theoretically if i ran a 9"f and 10"r both with say 265/35/18 tires, obviously one with a relatively straight up and down sidewall and one very slightly stretched, there would be no issue? or would the sidewalls pull the tire diameter down enough to create a difference,
not sure if there is a calculator for that?
Manufactures design the tire without stretching in the process. Tire stretching alters the tires overall dimensions which throws out every wheel calculator known. This is were a tire tape and knowing your calculus. Just how Nizmo Man stated, tire pressure will also alter rolling diameter. This is where I was stating mix matching tire manufacturers sometimes works because their specs of a 265 of a Hankook tire will be different of a 265 from Nitto. This applies across the board.
I know it's a lot to take in but your best bet is find the tire you'd like to run. I.e. BFGoodrich. Go to bfg's website and look at their specs for the tire. They'll give you a rolling outer diameter. Now the fun part is to find another tire with the same measurement. Here's another monkey wrench. Tire pressure is everything. You'd be running the recommended tire pressure at all times. So pressure up front will differ from the rear hence the two different tires. All specs given on the websites are given with the idea of the tire being properly mounted and properly inflated.
ok, cool.
I reckon you would, hence the different tyre sizes for the different wheel widths.
  • Like 1
  • 3 weeks later...
Hi all, i am new to this forum and this is my first post so bear with me. I am currently looking to buy wheels for my new r32 GTR. I have found a set that have the following specs.
Front: 18 x 9 +30
Back: 18 x 10 +18
Just wondering if anyone is running similar specs? Do the front clear the calipers? No need for any guard work?
Cheers
Front: 18 x 9 +30
Back: 18 x 10 +18
Cheers
Those wheels are terrible for your car.
Since you're new to the Internet, I'll help you out.
1. ATTESA does not like different rolling diameters. Stick to the same sized wheels and tyres all round. So you'd want either the front OR the rear sizes all round.
2. Brake clearance is determined by the wheel spoke design/space behind the spokes. You have provided zero information on what wheels they are besides the sizes, so your guess is as good as ours.
3. 18x9+30 is the standard R34 GT-R wheel specs, which doesn't require guard work (depending on how low you car is). 18x10+18 will require guards rolled and negative camber to fit.
Welcome to the forum and happy searching. Use Google e.g.: type this into the search (without quotes) "r32 gtr wheel fitment site:sau.com.au".
Thank you for the reply that definitely helped a lot. I didn't know about the attesa system not liking different diameters so that's great thanks. The wheels I am looking at are work GT5's, and I have changed the sizes to 18 x 9 +30 all around. Would they be more suitable??
Cheer
Awesome sounds good thank you for the advice!! The other size I'm looking at is 18 x 10 +38, but I'm unsure as to how they will sit. If anyone on here has photos of their wheel set up please post some!!
Cheers
As for the look, I want to run a clean close fitment but run as neutral camber as possible. If necessary I can roll the guards but I don't want to flare them and ruin the natural body shape.
Cheers
Nah, forget that spec.
Scroll up and read the last sentence on post #3328.
Cheer
Bro you need to google image that. Seriously.
Check out r32 gtr with r33 gtr wheels. That will answer all your questions.
New wheels for my R34 GTT
Front: 18x9.5 +27
Rear: 18x9.5 +27
Enkei NT03-M flat black
I am going to run 235/40/18 in the fronts, and 265/35/18 in the rears.
Any suggestions are welcomed.
Test fitment today, love them. Currently 265/35/18 all around, but tires are trashed.
Edited by 604JD
  • 4 weeks later...
guys- who's running 18x10 +22 or near size wheels & how much camber are you running to tuck them?
currently has 235/40 and they stick out a good 15-20mm~
got defected for them sticking out so only solution is to tuck them in as i dont want to change wheels,
last alignment i had was -1.4
i'm thinking close to -1.8-2 as i will be lowering it bit 20mm more so the top of the tyre just tucks in.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
