guys- who's running 18x10 +22 or near size wheels & how much camber are you running to tuck them?
currently has 235/40 and they stick out a good 15-20mm~
got defected for them sticking out so only solution is to tuck them in as i dont want to change wheels,
last alignment i had was -1.4
i'm thinking close to -1.8-2 as i will be lowering it bit 20mm more so the top of the tyre just tucks in.
I am assuming this is on a ST/T, not an R.
At that offset the entire rim will never be inside the guard. Adding more camber will just make the bottom poke out more.
Near flush on a GTST rear with a 10" wide is 30-35 offset and a 1.3"ish" in. Not sure what your regulations are to maintain a roadworthy car where you are at but it sounds like you'd have to either change your offset or possibly get flares to cover up. The others on here will have better insight on your local laws than I.
Another question guys. Looking at a set of wheels and I'm not too savvy.
They're 18" and 8" wide all round ET40. for my r33. Says 73.1 centre bore. Just wondering how they'll fit/sit. Cheers for the help :)
Get something with lower offset (e.g. +20-+30 for an 8"). Also depends how you want the wheels to sit.
Those ones will sit pretty much like the standard wheels.
Skyline model = r33 gtst
Wheel diameter = 18
Wheel width =9
Wheel offset =+20 on the rear that's all I'm looking at
Tyre size = 225 or 235
Modifications to fit = ?
Dose anyone have pics how it will sit. Car is lowered on coilovers
  • 1 month later...
Skyline model = R33 GTST
Wheel diameter = 17
Wheel width = 8/9
Wheel offset =+40
Tyre size = 225/255
Modifications to fit = None
Wheel: Inter Milano 17" Wheels
On the other hand
Wheel diameter = 18
Wheel width = 9/9
Wheel offset =+15
Tyre size = 225/40 245/45
Modifications to fit = Won't fit, hits side skirts, hits guards, hits everything. Need smaller profile.
Wheel: D1R's
Car isn't all that low either. I have 115mm clearance at the lowest point. I've gotta wrap the new wheels with 35 profile on the rear and can MAYBE get away wit 40's up front.
what would be the better option for an r32 gtst 2 door, 17x8.25+25 or 17x8.25+35? will be running 235/45 tyres all around, i know i can tuck both under stock guards but i want to be able to tuck the rears with between 0-1 degree negative camber so which would be the better option? guards are currently all stock but wouldnt mind rolling them, not to keen on doing much more, thanks!
Might as well post up my current setup
Skyline model = R32 GTST
Wheel diameter = 18
Wheel width = 9
Wheel offset =+27
Tyre size = 225
Modifications to fit = bit of camber on the rear from lowering the car
Wheel: Rota g-force
Does anyone have issues with front wheels unable to full lock steer or touching the front most point of the side skirts in their 33? I don't know why but just looking at my car from the side, the wheels look to sit further back of the centre of the wheel arch...
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
