to my above question
i asked a mate who has had a different sets of rims on hes 32 and reckons that the 18 x 9 +30 will be fine
he suggests a 215 front tyre and 225 rear, i dont mind having tyres stretched a tad and will suit the car nicely
sorry for all this newbie questions not the best with offsets and that
Cheers
u can make it fit, depending on the tyre you run up front and the offset all around.
18x9.5 +35 with 255/35 all round. Would that fit without needing to lip/flare the guards? Also, would that be the most suitable size tyre, or should I be looking at 235/40 or something?
235/40 would be a much better option for a daily driver, 255's will scrub on the guards and possibly on the suspension up front. 255's are overkill, especially up front, better of spending more a quality smaller tyre. also not 100% sure about 18x9.5 +35's fitting up front, id be worried about upper control arm clearance, saying that im not too sure how much clearance R33's have.
quick questioin
which would fit better to my sedan
18 x 8 +35 all round
or
18 x 9 +30 all round
car will be fair low as well, so might need liping?
Cheers
depends what tyres u run, if u run relative sizes for each width, for example a 215 on the 8" and a 235 on the 9", the 8" with the 215 will have more clearance both from suspension and guards. 9" will sit a lot more nicer and allow better sized tyres, and still fit as long as u long as u dont run over a 235-245 up front.
Cheers
215 and 225 will be fine, but as i said u could get away with a 235 up front, and probably like a 255 up the rear if u really wanted.
first id ask why u want to run 255's all round, u could get away with smaller tyres easily while maintaining the same traction. im not 100% sure how much inner clearance there is on a R33, but id suspect u couldnt go much over a +35 at the front, to be safe id probably go +30, even so ur looking at issues with guard clearance. id be going a quality 235 instead, will probably cost similar $$ and provide better steering response and clearance.
For circuit work, with slicks
For road rally work i am thinking 8F & 9R
Hey I'm looking at buying some 20"x8" (yes i know 20s on a skyline is a bit of overkill, i want something that will really fill the guards though)
anyway, just wondering if they will fit
20x8
+42 offset
235/30/20 tyres all round
my cars lowered on adjusties, isn't slammed, sits at a nice level, bit lower than super low king springs
Cheers
and no they aren't bling bling chromies lol, they're dished black wheels
Edited by GTS4onP
20x8
+42 offset
Cheers
doubt it, rear they will probably fit no worries, fronts i strongly doubt it, will most likely foul on the UCA's pretty bad.
20x8
+42 offset
:P:down::laugh:
Quick question, do you think 17x9 +20's all round with 225/40 tyres would be too much for a R32 GTST 2 door with stock guards at quite a low height (currently 17x7s all round, tyres in guards almost)?
Edited by Ceffy_SA
^^will sit very nice depending on camber, but u will need to roll the guards, no pulling or flaring needed.
Ok thanks that was the answer i was looking for, not my car but a friends, will be having the wheels fitted by Wheelworx this weekend, sill put pics up when its all done.
Any thoughts on R33 GTR rims (17x9) on a 32 GTSt?
I have a set and they fit fine with stretched 215/45/17 rubber. I am planning on using them as track wheels so I can run 235/40/17 RE55's all round and rotate them.
I'm expecting to need to flare the guards a bit but i don't mind that. Might even buy fibreglass front guards that are wider.
I'm a bit concerned about hitting the suspension. Has anyone had this combo before with wider width rubber?
thanks,
Russ
Wheel diameter = 18
Wheel width = 9.5
Wheel offset = +35, but with the 15 mm spacers this has changed. Can somone tell me what they are now? +20?
Tyre size = 235/45/18
Modifications to fit = 15mm bolt on spacers all round to clear the brakes + lipped and rolled guards.
Yeah 20 now. Further out is a smaller number. That's a pretty aggresive offset! Did you need the spacers to clear the suspension?
thanks,
Russ
i ran 235/45's all day every day on R33 GTR rims, 17x9 +30 with a 235/45 is pretty much the limit for inner clearance, u wont need a flare to fit it in the guard, but ull need to roll the guard, which is something u need to do to fit any decent size wheel. depends how much camber u are running as well, but imo its perfect size for stock guards.
Hi guys, as for me I have
Skyline model = R33
Wheel diameter = 18"
Wheel width = 8" front, 9.5'' rear
Wheel offset = 35
Tyre size = 235/45/18 front, 265/45/18 rear,
as for winter (here in Russia its a bit snowy :D ) I put on rear 245/45/18
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
