I attempted to use search for this, but it came up empty.
I searched for a known size, still naught.
Don't think it likes numbers.
So........
Anyone know/ have pics of 18x10.5 +22 on a 32 gtr?
How close are we going to get to guards, suspension?
Justin's 32 gtr would be closest to these spec
http://www.speedhunters.com/2011/03/car_feature_gt_gt_justin_fox_s_r32_gt_r/
He's running abit of camber up front (more than 3 if i remember), he has a build thread on JDMST
If this is the wrong place to ask, let me know and I'll start a new thread!
Will 18x10.5 +22 with 265/35R18 fit an R32 GTR at standard height without issue?
Any modifications required?
What if I want to go lower in the future - say low enough such that the top of tyre is flush with the guard.
Wheels I am looking at are Work S1Rs, so offset is customizable in 1mm increments over a huge range.
Hi guys. Looking at buying a set of 18x9.5+18 F 18x10 +15 R to fit a 33 gtst. Gaurds rolled and pretty much stock hight. Interested in any advice, will they fit? Anyone else running similar spec and any input. TIA
Edited by GTST520
looks good, thanks for the link :thumbsup:
  • 3 weeks later...
sooooo im looking at ROTA grids.. (yeah yeah but im too povo for TE37's and the stockies are looking a bit tired)
which would fit better on a 34 GTT without flared or rolled guards?
18x8.5 +30 or 18x8.5 + 44?
just looking for a good fitment without any scraping/rubbing/stretching/modifying
(i've tried looking back through all the threads but i cant seem to come up with a simple answer which would fit)
edit:
just found a post from 2006 that was selling a set of LMGT4's which looked alright
(18x8.5 +30 and 18x9.5 +38 if anyone was wondering)
might see about upgrading the rears
Edited by lench
edit:
Go the 8.5+30. Shouldn't have any issues at all at stock height. Won't be an aggressive fitment at all though. Would be very stock looking.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
