Hi folks, would you know what size wheel is on Garage Yoshida's shop car?  More specifically the width.  I look up BBS' lineup and that looks to be their RI-A wheel, either 18x9.5 +22 or 18x10.5 +18.  I first thought it must be the 9.5" because it's on R32, but looking at the front wheel to fender gap I am not so sure.
Rolling shot starts at 0:26 mark.
Edited by TXSquirrel
On 3/3/2020 at 7:54 PM, niZmO_Man said:
Judging from the stretched tyres, 10.5 with 265 wide tyres.
I always wonder how could R32 run 10.5" wide wheels.  I have 17x9 +22 right now and it's already lined right up to the fender in the rear.  Front strangely still has space though.
I have 10" +20 with 275/35 Hankook RS3
All guards rolled
-2.5deg camber front
-1.5deg camber rear
Just fits haha. I want to go 285/30 as current tyres are a little stretched.
but yes, for a street setup, non vapegram spec, 9" +20's is plenty
  • 3 weeks later...
Waiting for my car to arrive from Japan later this month and i'm looking at 3piece wheels.
4door 32 people how would 18x8.5 et29 & 18x9.5 et29 fit? Im after a tight fitment & I dont mind running a small amount of stretch.
See pictures below.
These are the wheels I am about to buy. I have a r32 sedan type m, so it has the bigger brakes & 5 stud obvs.
You guys reckon they will clear breaks fine? its hard to get all this right without having the car hah. Gonna be running the car fairly low too or what ever it takes to get tight fitment between tyre and fenders ?
On 09/04/2020 at 6:49 PM, Frostyr33 said:
Skyline model = BCNR33 GTR
Wheel diameter = 18”
Wheel width =10”
Wheel offset =+20
Tyre size =265 / 40 / 18
Modifications to fit = Ohlins coil overs
Are you sure it's not 265/35, because why the hell would you go a 265/40R18 ? That's a 20 - 25mm + larger rolling diameter (670mm) than the factory range of 235/45R17 to 245/45R17 (642mm - 651mm).
265/35 or 275/35 on 18's on a 33 or 34 generally if you want your Speedo to be at all accurate, as above will read about 5% under, as in reading 95 when you're really at 100.
On 3/30/2020 at 9:56 AM, Adz2332 said:
what was that website called that has pics of cars with the rim specs they are running etc?
have a stinger and looking for pics of a few wheels in the odd offsets they will need to be
https://www.rimtuck.com/
?? Perfect. I noticed they are AD08R. Interestingly, which I just found out when I fitted them to my 32R, is that they are a bloody big tyre.
I have Advan V103 on my 33R in 275/35R18 and recently fitted the Advan AD08R on the 32R in 265/35R18 - the 265 is a much bigger / wider tyre than the 275. Great for a 33, but pushing it on the 32 without a fair bit of camber.
Has anyone else found this with the AD08R being not comparable other tyres, as in, a LOT wider for a given aspect ratio ?
Hey guys I need emergency help!
I currently have an R34 GTT with Tein Coilovers
Looking at buying LMGT4 in 19”
FRONT: 19x8.5 +25 with 245/35/19 tyre
REAR : 19x9.5 +30 with 275/35/19 tyre
With these fit without rolling guards or anything?
Screenshot is vs current setup which has only slight rubbing at the moment on full lock!!
Edited by BlazenR34
7 hours ago, Predator1 said:
Seeing that you're going from a high to lower offset wheel, I would suspect they would rub a bit more. What's your ride heigt and camber?
Not sure about camber atm but the measurement from the ground to the top of the wheel arch is 650mm.
Does anyone know what the perfect fitment/rim size/offset for LMGT4’s would be in 18” and 19” for flush fitment to the guards.
Edited by BlazenR34
Newbie to the forum here. Looking for some advice from someone who has experience with 34 GTT 2 door's.
Looking at 18x8.5 +30 Fronts, 18x8.5 +35 Rears.
Car is lowered on coil overs, no guard roll. Will this be a good fitment? After a very slight poke if possible. Looking for semi-aggressive fit without drawing to much attention from the po po. Don't want to roll guards and have to worry about scrubbing.
Prob go 235's front and 265's rear if that fits. Would prefer 255's rear but its uncommon size.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
