  • 1 month later...
2 hours ago, niZmO_Man said:
You trying to put 8.5" +18 on the front?
Correct. The car is lowered, but trying on my roommates R32 GTST it also hits in the same spot on his car and he's pretty much stock.
Edited by sommyken
  • 1 month later...
Hey guys, I have an R32 GTS-t that I am doing a GTR front end swap on and I can't find anything on wheel specs for front wheels? I've been looking and have specs for the rear when using overs but nothing for front wheel specs with GTR front fenders on a GTS-t. Anyone got some info?
What? BNR32 wheel is 16x8 +30, this is plastered all over the internet.
I know that, I should've specified the size of wheels I'm trying to use. I'm trying to fit a 245/35/18 so the +30 isn't going to work.
  • 1 month later...
Hey guys needing help, trying to order some wheels currently and they need the specs of the calipers and such. Well I’ve taken the car to a mechanic and they’ve written down what they can and apparently it’s not enough so I was wondering if anyone has Cr 2p or 3p on their 33 Gtst and what disk type they chose? I’m planning to go 18x10.5 +15
cheers
cheers
Do you have GT-R guards? Or equivalent wide body?
Go to Work Wheels website and load up the specs PDF
  • 4 weeks later...
2 hours ago, Adz2332 said:
hey all
i cant get a cheap square set of AME Tracers for my 32 gtst
they are 18 x 9.5 +15
what are the chances of getting them under my gaurds? much of a roll?
I have a set of TE37SL's in 17 x 9.5 + 12 that fit well with a bit of a roll, an aggressive alignment and some slightly stretched tyres
would love to see pics mate
Skyline model = R34 GTT
Wheel diameter = 18'
Wheel width = 8.5
Wheel offset = 30 F and R
Tyre size = 265/35/18 (Overstretched by 1 size)
Modifications to fit = You will require some camber on the rear and front (nothing crazy) but will not scrub as tested at SMSP. I have since lowered the car by 20mm and only experience MINOR scrubbing on the un-rolled front guards.
Fronts: un-rolled
Rears: un-rolled
8 minutes ago, Ravskie said:
Wheel width = 8.5
I don't understand. That is not stretching the tyres onto the wheels at all. The correct tyre size for an 8.5 " wheel would be 235 or 245. A stretch would be a 225. Cramming a 265 on there is a big, baggy bulbour 1970s style fitment.
Yeah, only old commodore owner do that because the oversized tyre cannot make a commodore handle any worse than it does originally.
tbf I have 265's on a 9 and it looks almost completely square with the rim.
Forgive the blur. I could conceive someone putting it on a 8.5, but yeah I wouldn't spend the extra money on that when 255/245/235's are a thing.
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
